Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 18th March 2014, 05:11 AM   #1
eimis is offline eimis  Australia
Send a message via Skype™ to eimis
Unhappy Mistakenly ordered a 100k pot for O2 amp.
Hello,
I mistakenly ordered a 100k step pot for my DIY O2. I've been using a wiper 10k pot in it, but experienced some balance problems.
How bad is it to use a 100k pot in it? What problems would this cause? Thanks.
Old 20th March 2014, 11:01 AM   #2
Volume control won't be quite so log beyond the 12 o'clock position or so. Maximum noise level increases by a few dB. Probably somewhat higher distortion.
If you had balance problems with the pot, you probably either had a cheapie pot, got unlucky with the particular sample (RK09s may apparently vary a bit) or had too much voltage gain. If your sources are relatively loud (like CD player level), even the usual medium-sensitivity hi-fi cans tend to be quite happy at 0 dB gain, so a 1/2.5x gain config may be all you ever need.
OK to Sub 100k Pot For 150K? hj808 Analog Line Level 4 30th May 2010 05:42 PM
100K pot in a preamp? G Tubes / Valves 5 15th May 2008 02:41 PM
Noble 100K pot. mattjk Swap Meet 0 21st January 2008 02:50 AM
Effect of using 50k pot instead of 100k pot in tube preamp? KT Tubes / Valves 5 17th February 2006 09:56 PM
100K linear pot annex666 Swap Meet 7 27th September 2003 11:13 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
