Help my cmoy is popping caps - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 26th December 2013, 10:35 PM   #1
d0ugb is offline d0ugb  United States
Default Help my cmoy is popping caps
So i need some help,
This not my first cmoy build, however this is the first time I have attempted to design my own schematic, and PCB layout. I have been wanting to try the tle2426cp instead of using the resistor method of rail splitting, however I am having issues. The cap I am using for the power supply is over heating and popping, which is in turn causing the tle to get incredibly hot. Attached is a copy of my schematic, and my board layout. Please if you can let me know if there is anything obvious thanks!cmoy1.pdf
cmoy2.pdf
I am using the schematic and idea from this site:
isendev.blogdns.org
Old 26th December 2013, 11:06 PM   #2
godfrey is offline godfrey  South Africa
Is that a double sided board? In the layout you showed, some connections are missing. e.g. the output of the rail splitter isn't connected to anything besides CNR.
Old 26th December 2013, 11:55 PM   #3
DUG is offline DUG  Canada
Questions:
Is the supply feeding this board connected with anything else?
Have you rung out the board? (checked with an ohmmeter that connections are where they are supposed to be)
Comment:
I would have made the GND an actual bottom side ground plane rather than have the GND path wander all over the board. Then when you need a connection to GND you just connect to the bottom of the board right at that spot.
Happy learning
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 27th December 2013, 03:45 AM   #4
The rail splitter connects to the CNR then out to the opamp via a small jumper. I have checked for shorts, but I have not checked to the resistance with an ohm meter. Its a single sided board, I have a connection to ground with which I plan to connect to a mounted stud inside my project box. I used the auto router when I laid our the board. I need to start the board from scratch, however does the schematic look fine?
Thanks for your help!
Old 27th December 2013, 02:17 PM   #5
Avro Arrow's Avatar
How much voltage are you powering the amp with?
What is the voltage rating of the cap that fails?
You might want to read this.
Last edited by Avro Arrow; 27th December 2013 at 02:20 PM. Reason: added information
Old 27th December 2013, 02:22 PM   #6
Avro Arrow's Avatar
The autorouter is awful.
Use a two layer board with a ground plane on one side.
Lay out the traces manually.
You can get boards made here pretty cheap.
What is oil can popping of a sub Amit_112dB Subwoofers 3 30th January 2013 01:38 AM
FS: Capacitor Lots: Oil caps, HV Film Caps, Polystyrene Caps mattattnet Swap Meet 1 8th December 2012 09:20 PM
popping speakers e30mad Car Audio 8 4th February 2012 12:50 PM
Cmoy Caps noobman92 Chip Amps 8 12th February 2011 05:27 PM
Midrange keeps on popping pjaneiro Multi-Way 20 1st January 2007 01:07 AM
Copyright 1999-2017 diyAudio
