Headphone Systems Everything to do with Headphones
Current source in diamond buffer
Old 29th November 2013, 10:08 AM   #1
proid is offline proid
Default Current source in diamond buffer
When adding current buffer for a diamond buffer instead of a resistor, do i need to closely match the current source between rails? And does low noise jfet like 2sk170 have better performance here or whatever like 2k246, 2n5484, 2sk30 ... will do the job?
Old 30th November 2013, 12:11 AM   #2
Shaq888 is offline Shaq888  Ukraine
Shaq888's Avatar
10% of mismatch is fine. It is not as important.
Noise is does not really matter that much, especially is buffer will be inside a feedback loop.
As an alternative you can use a bootstrap. It works good if you have regulated or relatively stable power supplies.
Also you can somewhat modify buffer connecting collectors of the front pair to the emitters of the opposite output transistors. In this case it will work like Baxandall super pair. It will make a buffer somewhat more linear and will decrease and keep constant power dissipation of the front transistors.
Another thing to consider. If you are going to use it inside a feedback loop, like with opamp etc, it can be useful to add two small capacitors from the input of the buffer to the bases of the output transistors. It may slightly compensate a phase lag, which is always good in this application. Although it is not a universal mod. Result will depend a lot on transistors types and bias currents.
Current source in diamond bufferHide this!Advertise here!
Current feedback high speed headphone amp with diamond output buffer peranders Headphone Systems 106 20th August 2015 01:51 PM
Diamond Cascode, a Diamond-like buffer/current booster linuxguru Analog Line Level 30 31st October 2013 05:20 PM
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 01:46 PM
Diamond buffer + source follower Mr Evil Solid State 12 24th August 2009 11:28 PM
Diamond buffer peranders Solid State 45 15th November 2003 11:00 PM
