My new headphone amp - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 25th November 2013, 01:31 AM   #1
Algar_emi's Avatar
Default My new headphone amp
Hi. Here on of my newest project. It is a fully dual mono all discrete FET headphone amplifier in Class-A. Real Class-A at 100ma per supply, and channel. With supplies of +/-24V it is 9.6W in Class-A (200ma * 48V = 9.6W). It is cooking
It sounds superb, perfectly silent with dual fully discrete low noise regulators with CRC pre-filters. The case was made by Front Panel Express, side wood panels in exotic Padouk wood with oil finish.
The circuit is DC coupled, we no coupling capacitor in the signal path. A servo takes care of the small circuit thermal drift.
Here the prototype pictures
File Type: jpg All Fets Line Amp & Headphone_small.JPG (154.7 KB, 630 views)
Old 25th November 2013, 01:33 AM   #2
Algar_emi's Avatar
And the completed amp. It is using great parts everywhere Furutech AC power inlet, Non-magnetic line noise filter (aka Ayre es filter), Low noise vibration decoupled dual toroid transformers, Philips/Vishay huge pre-filter caps, Wima, Nichicon KG/Muse, CDE and Vishay caps, Caddock MK132 and Vishay CMF55 film resistors, Noble volume pot, Canare power & Mogami audio cables, 6N single crystal copper hookup wires, Cardas and Amphenol connectors and the classic blue led power on indicator.
Even the bottom is nice, with vibration decoupling feet, laser trim ventilation holes and concealed power-on switch.
Old 25th November 2013, 01:40 AM   #3
Algar_emi's Avatar
The power section is all assembled point-to-point. I did my own PCB. Ventilation holes can be seen on the back. You cannot see it but there is bitumen vibration absorbing pad under the top cover. Front and Back views. It is real statement amp, top of its class. Difficult to do better I guest...
Old 25th November 2013, 09:37 AM   #4
jacques antoine's Avatar
Any schematics?
Old 25th November 2013, 11:12 AM   #5
Nico Ras's Avatar
Why do you run a headphone amplifier from +/-24V rails? I would think it is wasted energy dissipating 9.6 watt if 200 mW/ch would certainly damage most headphones/ears.
Kindest regards
Nico
Old 25th November 2013, 12:11 PM   #6
Algar_emi's Avatar
Sorry no schematic. This is a design is copyright and I cannot disclose any details. This circuit can also be used as a preamp, single-ended or balanced. Indeed the supply can be lowered to +/-18V, but the regulator will then dissipate more heat. Input of the regulators are +/-31V. I may try that to lower the amp dissipation. It is a balance between amps and regs.
Old 25th November 2013, 02:09 PM   #7
gk7 is offline gk7
Originally Posted by Algar_emi View Post
Sorry no schematic. This is a design is copyright and I cannot disclose any details. ...
Why post it on a _diy_ site then ?
Old 25th November 2013, 03:09 PM   #8
Admiration only
Old 25th November 2013, 04:59 PM   #9
Avro Arrow's Avatar
Free Advertising?
Old 25th November 2013, 05:12 PM   #10
aparatusonitus's Avatar
Judging by a small visible part of PSU schematic, it's one of Erno Borbely design: all-fet Super-shunt regulator as well as all-fet Preamp.
Non mai abbastanza...
My new el34 + 12ax7 VCT amp. (Need Ideas For my first headphone vacuum tube amp Too~) briansune Tubes / Valves 10 12th July 2013 06:33 PM
recommend me a valve headphone amp - Beyer T1 & AKG Q701 etc gbullimore Headphone Systems 5 18th April 2013 05:39 PM
Tube amp OPT for Headphone Amp? (impedance matching question) rongon Tubes / Valves 21 3rd January 2012 05:20 AM
2x Gain pure op-amp headphone amp idea Dxvideo Headphone Systems 30 10th September 2011 03:05 AM
SDS Labs Headphone amp. Anyone built it? can it be converted to a power amp? JCoffey Headphone Systems 1 30th May 2003 01:11 PM
Copyright 1999-2017 diyAudio
