DC servo for Sijosae Buffer - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 1st November 2013, 05:54 PM   #1
Default DC servo for Sijosae Buffer
I want to build a buffer only without the gainstage but when i try with the sijosae buffer, i got about 200mV dc offset. Can someone suggest me a dc servo schematic to build . Here is the Sijosae Buffer:
Old 1st November 2013, 06:25 PM   #2
Avro Arrow's Avatar
Here is a basic servo.
You will also need some resistance
to isolate the servo from whatever
is feeding the buffer.
Old 1st November 2013, 06:33 PM   #3
That mean i need to add some resistance to the output of the servo to the input of opamp? How about 10k? I see C1 and C2 is 10uf, is this value too high? I often see 0.47-1uF in other servo?
Old 1st November 2013, 06:50 PM   #4
Avro Arrow's Avatar
Like this:
Old 1st November 2013, 06:57 PM   #5
Avro Arrow's Avatar
R1/C1 and R2/C2 form low pass filters.
You want the F3 to be as low as practicle.
Too low though, and the time constant gets
too long.
1 meg and 1uF would yield the same time constant as 100k and 10uF.
Old 1st November 2013, 07:01 PM   #6
Avro Arrow's Avatar
R3/R4 set the servos authority.
Less authority means less effect on the
incoming signal.
With 1k and 10k the authority is 10 to 1.
For every 1 volt of offset at the source,
you need 10 volts from the servo.
PCB design of parallel of two inverted LM3886 with buffer and dc-servo. Roushon Chip Amps 74 11th April 2012 11:17 AM
Gainclone with buffer & DC servo Dxvideo Chip Amps 14 14th April 2009 12:22 PM
LM3886, XO, Buffer and Servo jackinnj Chip Amps 3 30th October 2008 12:14 AM
DC blocking cap in feedback path or DC servo? roender Solid State 27 19th September 2007 09:40 AM
Copyright 1999-2017 diyAudio
