connect two inverting op amps together - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 23rd November 2013, 11:17 PM   #31
Johno is offline Johno  Australia
Johno's Avatar
Perhaps head phone load at gain = 4 exceeds the output rating, unless you have a finger (around 1k at that voltage) in series with the load.
And now you know why it is good to minimise as well as balance the input resistances to op amps. Note that while fet inputs have high DC resistance they also have large input capacitance, it is the capacitive current with AC signals that acts like an input bias current and causes amplitude distortions when unbalanced rather than DC offsets.
I hope you are now learning to carefully evaluate what people here say.
Old 23rd November 2013, 11:54 PM   #32
nigelwright7557's Avatar
While you have had lots of advice on resistor values around op-amps no one has mentioned the power supply.
Make sure you use star grounding or you will get massive hum.
I threw together a pcb for a 6 channel mixer and when I built it the hum was at an unbearable level.
I found the hum was coming from smoothing capacitors charging up and causing a pulse on the ground line.
I re-laid out the pcb with the power supply separated and it worked a treat.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
non inverting op amp input impedance help sirus the virus Solid State 5 8th December 2010 07:11 PM
Inverting op amp out of phase? RobertE Analog Line Level 10 2nd December 2010 08:12 PM
Burr Brown op amps,in amps,power op amps for sale magneticnorth Vendor's Bazaar 1 23rd September 2010 11:50 PM
inverting / non-inverting op-amp circuits Learnincurve Solid State 11 21st January 2005 06:40 PM
Inverting/non-inverting Op-amp Inputs !!!help!!! IIR Solid State 17 11th May 2002 03:02 AM
Copyright 1999-2017 diyAudio
