Headphone Systems Everything to do with Headphones
Looking for a Headphone Amplifier
Old 17th September 2013, 11:37 PM   #1
weemo is offline weemo  Canada
Default Looking for a Headphone Amplifier
So..let me introduce myself to the forum. I am new to this whole amplifier thing. I have my Grado Lab headphones which I love and my good cowon mp3 player..started looking for amplifiers, started from the commercial ones, ended up in DIY amplifiers. From the tinbox to the o2..From LME-49990 (because I keep hearing is a good OP-AMP) to this website. Anyways...I could tackle a simple DIY..The problem?? so much information but alot is outdated. I need simple pointers to the most recent DIY stuff with my beginning knowledge in mind.
Thanx!
weemo
Old 18th September 2013, 01:06 AM   #2
davym is offline davym  Scotland
Hi weemo, I recon the Cmoy is probably one of the easiest to make, it's quite cheap and if you don't want to have to make a board and source components there are some decent kits around. You can get an idea if you do an ebay search for Cmoy kit, the dual chip version sounds very good indeed through my Grados for the little amount it cost to build.
Old 18th September 2013, 01:59 AM   #3
THanks for this. So, I went to ebay as well. There are alot of DIY kits, Chinese, doesnt matter which one?? also, if I get a kit, would swapping the OP-Amp with lets say a more expensive one, does that guarantees better sound? Thanks again!!
Old 18th September 2013, 02:41 AM   #4
jackinnj is offline jackinnj  United States
jackinnj's Avatar
When Dick Marsh wrote up his HA in Linear Audio I had some PCB's made up -- check out the thread. It's a beautiful device capable of driving low impedance loads at low THD.
Old 18th September 2013, 02:55 AM   #5
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
A simple pointer? Get into winding your own transformers, then almost any amp you already have can be your headphone amp. I've never heard my Sony CDR3000s sounding as dynamic as when I connected them to a simple chipamp via a step-down transformer I wound myself on a cheap ferrite core.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 18th September 2013, 03:18 PM   #6
Shaq888 is offline Shaq888  Ukraine
Shaq888's Avatar
Hey
Just finished a proto of a semi portable amp. This thiny can be powered from single 9V battery and will work almost down to 4V.
With 9V supply it can give something like 60-70mW into 32Ohm load, which is usually more than enough.
The spectrum shows amp driving 35mW into 33Ohm resistor at 1100Hz.
If you are really interested, I can spend some and make separate PCB layout with tinier connectors.
Old 18th September 2013, 04:17 PM   #7
randytsuch is offline randytsuch
I think you can still order one of these
wire board group buy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 18th September 2013, 07:21 PM   #8
sgrossklass is offline sgrossklass  Germany
If you don't know what you want, chances are everyone will propose their favorite project.
It's generally better to start from sort of a performance spec. Like, what requirements do you have for the amp (size, portability, powering, features, sources)? What sort of budget do you intend to invest? (Usual hint: You generally don't DIY to save heaps of money.) And what is your skill set in terms of soldering, measurements and whatnot, and what sort of tools do you already have?
I think for 32 ohm cans like Grados, a cMoy with a beefy opamp like a 4556 (or an RA-1 clone, which is much the same) would be the minimum.
As far as ordering finished PCBs/kits, be prepared for bugs of some sort or other with Chinese sources in particular. At least it's quite hard to mess up a cMoy, but getting part values wrong is still an option...
Old 18th September 2013, 11:17 PM   #9
wow..Thanks for this..seems like I have my hands full on a project like this. Obviously is a mix of things that determine the quality of the sound and that requires reading/research...Its been such a long time since I last used a soldering gun!!! Its something I can tackle though. Reading schematics is a different story, new to me...So, all in all, I think I will do both. Buy a built cMoy and keep researching and eventually tackle my own built..
Thanks for all the replies. All indeed helpful. Cheers!
W.
Old 19th September 2013, 02:57 AM   #10
Avro Arrow is offline Avro Arrow  Canada
Avro Arrow's Avatar
You should check out Freds Amps
Looking for a Headphone AmplifierHide this!Advertise here!
Headphone amplifier Tekko Solid State 7 27th June 2011 04:41 PM
help on headphone amplifier theChris Headphone Systems 27 18th July 2010 06:36 AM
headphone amplifier sparkle Headphone Systems 31 15th October 2007 12:33 PM
Headphone amplifier audiofan Headphone Systems 5 3rd March 2006 04:43 PM
headphone amplifier?? sunrise Headphone Systems 0 20th August 2005 12:17 PM
