Headphone equalization hardware and software - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 10th September 2013, 04:05 AM   #1
agdr is offline agdr  United States
agdr's Avatar
Default Headphone equalization hardware and software
Even though most headphone amplifiers have a fairly flat frequency response across the entire audio band, most headphones don't it seems. Such as these curves for the AKG K550:
The Wonderfully Competent AKG K550 Sealed Headphone Page 2 | InnerFidelity (scroll down)
I'm curious if anyone knows of any headphone equalization hardware and/or software that can equalize the frequency response curves of specific headphone models. By this I mean being able to select a pre-determined set of equalization values from a table to correct a given headphone model's specific frequency response glitches, not just fiddling with the sliders on a multi-band parametric equalizer.
I'm aware of two so far. This hardware "headphone correction filter PCB" by "solderdude"
Headphone | DIY-Audio-Heaven
which is essentially a high and low shelving filter followed by a 2 band parametric equalizer. The "low" shelving filter is the same circuit I use in my desktop headphone amp for bass boost. He has a table of part values to equalize the curves on 35 different models of headphones.
Then there is the headphone equalization software from Audyssey built into their Media Player app for the iphone:
Improve Your Headphones | Audyssey Media Player
Audyssey apparently has well over 100 headphone models in their equalization database. The software is a great solution if you use an iphone, but I don't and Audyssey says they have no plans for an Android or PC version.
Any others out there?
Old 10th September 2013, 12:41 PM   #2
I have a Superlux HD681 headphone.
I have made a similar filter to the one with the 470 mH and 3.3 mH coils in DIY-Audio-Heaven.
I used LTspice and modelled the output impedance of my HiFimeDIY UA23 DAC and input impedance of my phones to filter out the peak in the upper frequencies. I used the graphs from the Headphone Learning website.
I used polyester capacitors and wound my own air core coils. I used variable resistors for tweaking, which I still need to do. Cannot find the time in the near future. I mounted the parts on a piece of wood, intending a prettier box later.
My coil and capacitor sizes were slightly different. I wound my own coils, so not limited to manufactured values.
This system is a significant improvement over unmodified Sennheiser HD580's, in that the bass is more natural.
The results are fantastic. I cannot stop listening to music now. True audiophile quality for about $100 USA, including the DAC, filter, and headphones. It works with any computer.
Just the facts! State your evidence.
Old 10th September 2013, 03:28 PM   #3
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default How-To: Auto-EQ is published -
Funny you should ask --- I published an article in Linear Audio magazine last year that does just that --> auto-EQ for headphones using the Audysses system but any type of auto-EQ will work, of course. It is part of my Hi-End headphone amplifier article. Its all there on how to do it. Not a generic EQ curve but an EQ for your head/ear/phones using a probe microphone which you can easily/cheaply make.
Its all right there for you.
Thx-Richard Marsh
Old 10th September 2013, 06:06 PM   #4
agdr's Avatar
Thanks for the feedback! I have actually been thinking about getting that HiFime DIY async DAC. I just noticed last week that he had those available now. I have his $30 ODAC clone. Good to know that the eq circuit for the 681 does the job. Yeah I've been kind of guessing that some accurate equalization would go a long way to closing the gap between midrange phones and higher end cans. Sounds like it does!
Richard - thanks for the heads-up on the article! Looks like that is volume 3 from last year. I'll get it on order from Jan. I've been wanting to read an issue of LA. Good point that ears are part of the system and should ideally be included in the equalization too.
Old 11th September 2013, 09:12 PM   #5
As soon as I hear that the async DAC is better than the original UA23, I will order one.
If there is a USB DAC that gives a better bang for the buck, I would like to know.
Old 11th September 2013, 10:04 PM   #6
gk7 is offline gk7
Auto EQ:
Would equalizing for a flat response direct on the ear canal not be the wrong thing ?
If you take into account the influence of the head shape and the outer ear, would not
a diffuse-field equalization be more appropriate ?
Auditory environment
Old 11th September 2013, 10:52 PM   #7
In my limited experience, a narrow peak in a frequency response in more annoying than a wide peak.
A narrow dip in a response is less annoying than a narrow peak of the same magnitude.
The overall flatness of the response in not as important and distortions.
If distortions are produced in an effort to flatten a frequency response, I would choose the less flat response. Is digital frequency modification distortion free? Clarity of sound in paramount.
Old 12th September 2013, 05:44 AM   #8
RNMarsh's Avatar
Default MLS water-fall plot of active LP filter -
Yes to all of the above.
Note that a flat frequency response with filters (crossovers) can be low distortion as well BUT it still is not percieved as Flat. This is due to the Q of the filters adding energy to the response at the cross-over freq. The total energy at the filters corner has its audible affects.
Thx-RNMarsh
Old 14th September 2013, 09:47 AM   #9
Sorry for missing some typo errors in the previous posting.
Thank you Richard for your interesting point about filters.
I had a most interesting visit with Joseph Manger in Germany at his home some years ago. I was impressed with his Manger speakers, in that they gave the orchestra some sense of depth in addition to the expected stereo spread. Also there was a huge sweet spot, completely different from electrostatic "head in a vice" experience.
The main concern he expressed about speakers is the importance of phase coherence. His theory was that the human ear was developed to hear the sound of the tiger creeping up behind your back, and the cracking of a stick would locate its position, based on phase difference of the sound reaching your ears. Listening fatigue is caused by crossovers in multi way systems, because the ear is genetically programmed to sort out location by phase, which is messed up by multi way speakers.
This has implications for the arguments used in feedback discussions, which sometimes leave me quite confused.
The Superlux headphones, have a very simple peak near the high end. It can be tamed by a simple filter, well about the most important listening frequencies, and hopefully does not ruin the phase problems through the main auditory frequencies. This makes it an outstanding headphone for its low price. The filter, in my opinion though is mandatory, not an option.
Old 14th September 2013, 10:22 AM   #10
I just visited the headphone learning site again:
Learning Center - Build a Headphone Graph | HeadRoom Audio
The graph for the HD681 headphone is a little different for the one I used 9 months ago. I took the peak to be about 7.5 kHz. This graph now shows 8.5 kHz.
Maybe the best thing to do is a measure the high frequency peak with a audio oscillator of the phones you are actually using.
78 equalization? Justinasia Analogue Source 12 22nd September 2012 02:02 AM
What is the Standard Equalization Whataudio Everything Else 1 4th January 2012 04:18 AM
LP to CD software/hardware recommendations? KP11520 Everything Else 17 12th September 2011 05:51 AM
Driver matching hardware and software. Colescuttle Multi-Way 2 12th October 2008 06:47 PM
Equalization Vaughan Car Audio 6 27th August 2007 04:33 PM
Copyright 1999-2017 diyAudio
