MOSFET follower to my phone - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 22nd August 2013, 01:09 PM   #1
Vigo is offline Vigo  Sweden
Vigo's Avatar
Default MOSFET follower to my phone
Hi everyone
I am considering to build a no gain head amplifier to use together with my phone.
I was planing to test this design Class A MOSFET Headphone Driver | HeadWize.
Do you think it will improve the sound from my headphones?
I use my phone as source (Nokia 920) and a couple of Denon headphones.
Thinking of buying some new headphones if the headamp turns out good.
To play with OP-amps in audio is like playing card with devil, you can never win.
Old 22nd August 2013, 01:29 PM   #2
If you decide to build this circuit, diyAudio members can suggest a few ways to improve the circuit design. For example, the PSRR* can be improved dramatically by modifying the R2/R3/D1/D2 network.
*Power Supply Rejection Ratio
Old 23rd August 2013, 11:20 AM   #3
JimT is offline JimT  Canada
I like mine. It needs a quiet power supply. In the future you could change R4 to a ccs.
Jim
Old 28th August 2013, 08:16 AM   #4
Vigo's Avatar
Hi
I have decided to move on with this project.
I have only a basic understanding of electronics so there are some question that i hope someone can help me with.
First it seams that the MOSFET used in the design IRF 513 is no longer available.
I think i have some IRF 610 at in a box somewhere, would these be possible to use?
Or can anyone suggest a good replacement for IRF 513?
I plan to replace the R4 with a CCS according to the sugestion from JimT.
Would it be possible to use a LM317 CCS with a potentiometer?
I am not sure if it could deliver enough current.
What other modifications is recommended?
Old 28th August 2013, 12:11 PM   #5
Avro Arrow's Avatar
Here is something I built. Works great!
You can eliminate the virtual ground and use output caps if you wish.
Old 28th August 2013, 01:13 PM   #6
Vigo's Avatar
That looks interesting, i am thinking doing something similar together with IRF610. What kind of OP-amp do i need for this, is more or less anyone ok or do it need some special characteristics.
Found this website of a head amp with IRF610, DIY IRF610 MOSFET Class-A Headphone Amplifier Project
Old 28th August 2013, 01:41 PM   #7
Input capacitors are probably a good idea too, since "Lin" and "Rin" are biased at +10 volts.
Old 28th August 2013, 03:39 PM   #8
Avro Arrow's Avatar
I know it isn't noted on the schematic, but input ground
and output ground are the same. With output/input ground
being virtual and the inputs being referenced to virtual
ground, there is no offset voltage at the inputs
Old 28th August 2013, 03:40 PM   #9
Avro Arrow's Avatar
There is no op amp.
There is a TLE2426 rail splitter...is that what you mean?
Old 29th August 2013, 05:33 PM   #10
You will be happy with Giovanni Militano's improvement over the original Szekeres. Remember that class A does take a large heatsink. The second post mentions an improvement to the biasing network for the mosfet. I do have this on mine, but it would not be needed with a regulated supply. I plan to build a Salas SSLV for mine, but have been spending my time outside enjoying the summer.
Have fun
Jim
Jim
MOSFET follower headphone amplifier GRollins Headphone Systems 187 2nd May 2017 01:26 AM
Selling mosfet follower tolikas Swap Meet 7 16th February 2012 08:30 AM
Anyone built this mosfet follower (or similar)? GregH2 Solid State 10 8th December 2009 09:34 AM
Driving a MOSFET power follower RichardJones Pass Labs 19 22nd July 2002 02:02 PM
MOSFET Power Follower help RichardJones Solid State 0 28th January 2002 06:01 PM
Copyright 1999-2017 diyAudio
