Headphone Systems Everything to do with Headphones
Crazy CMOY board
Crazy CMOY board
Old 6th November 2013, 03:41 AM   #31
Yurk is offline Yurk  United States
Originally Posted by avaniperen View Post
Hi Yurk,
How do you connect MNGD to GND/AGND if you use your first design? Can i just hardwire these grounds?
Thanks,
Alexander
The ExpressPCB board actually already has MGND tied to both grounds with a thermal pad on the top and bottom of the board. So, if you order from ExpressPCB, there is nothing else to do here, it Just Works (TM) as I intended.
MGND in this instance is just a place where the two ground planes come together, and since we're using a virtual ground, it just makes sure all ground potentials are equal.
The only exceptions are if you use the TLE instead of the discrete rail splitter design. In that case, you would tie MGND to TLE OPT (between the power supply caps). If you're using a split supply off-board, then solder your ground wire to MGND.
MGND didn't become a pain until I moved to Eagle.
Disclaimer: I'm an amateur. I reserve the right to be wrong. Your mileage may vary. Get a second opinion. Maybe a third opinion. etc.
Old 25th November 2013, 07:56 AM   #32
Default Power supply
Just a suggestion for a variable power supply to use in a non-portable environment.
Recommended at least 60VA, 3A transformer rated for your mains supply.
Heatsink also recommended for the LM317T.
Yurk
Crazy CMOY boardHide this!Advertise here!
Attaching SMD to prototype board is driving me Crazy... DonWarr Construction Tips 2 23rd February 2013 11:22 AM
New CMOY Hewie Chip Amps 6 21st March 2011 10:52 AM
My First DIY Audio Project: A Custom CMoy Test Board. isen78 Chip Amps 9 9th March 2011 01:58 PM
cmoy bb , jds board, self induced woes espressogeek Chip Amps 1 25th September 2008 04:59 PM
CMOY Help? sbelyo Chip Amps 2 3rd July 2004 10:14 AM
Copyright ©1999-2017 diyAudio
