Crazy CMOY board - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 24th October 2013, 03:07 PM   #21
sofaspud's Avatar
Yes, the wirepads in the component list correspond to identifiers in the schematic.
I thought XL-JMP and XR-JMP would be jumpers (and maybe they are on the PCB) but they are the crossfeed-to-gain-stage connections to RIN and LIN at the far left of the schematic, if I'm understanding the configuration correctly. It looks like only a dozen or so of the wirepads are for the panel-mounted components, namely the switches for the crossfeed circuit and the DC (with 12V regulators DCin needs to be 30-35 volts) power jack. There is no power switch or volume control. I don't know what GBY and GLEV are other than CAD placeholders.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 25th October 2013, 12:04 AM   #22
Yurk is offline Yurk  United States
You are correct! Oh, GBY and GLEV were there in case one needed to ground the bypass or level switches (in case of hum pickup), and they weren't using the case for a ground. All of the different connections are explained better in the ExpressPCB schematic, I haven't added them to the Eagle schematic yet. I'll see if I can get time to do that.
I wanted this board to be flexible, which is why there are so many options as to what needs to be stuffed and which holes lead to jumpers or to actual components. Sorry for all the confusion.
Disclaimer: I'm an amateur. I reserve the right to be wrong. Your mileage may vary. Get a second opinion. Maybe a third opinion. etc.
Old 25th October 2013, 12:31 AM   #23
sofaspud's Avatar
Not necessary to apologize. Thanks for clarifying. You ought to consider eventually fleshing this worthwhile project out a little with a proper component list, parts substitutions, enhanced option descriptions, pics, and that sort of thing. I have several hpa's but none with a crossfeed. I may give this a go myself.
Old 25th October 2013, 12:33 AM   #24
Default Here's the revised schematic
I added some info into the schematic, hopefully it clears up more confusion than it creates.
Old 25th October 2013, 12:35 AM   #25
Thanks for the encouragment. I will get a parts list up soon, I haven't actually built this board yet though. One of you may beat me to it.
Old 25th October 2013, 01:30 AM   #26
Default Board file
Oops, here's the newest board file with the extra hole by MGND needed to tie the grounds together.
Old 25th October 2013, 02:44 AM   #27
Default BOM
This should be a basic parts listing, of the entire board stuffed (with exception of the TLE). Broke the BOM down into Power supply, amplifier, and crossfeed sections.
Will still need to acquire ~30VDC power supply, and an enclosure. Was intending for this to be on a bench, not really portable. You could make it more portable with switch/power selection.
This is an Excel file, but will open with Open Office also.
Old 1st November 2013, 11:55 PM   #28
Forgot a jumper note in the schematic.
Mods, could we change the title to Crazy A47 board? Thanks.
Old 2nd November 2013, 12:04 AM   #29
Ideas for different ways to load the board, with graphics! Any part in black is needed for that particular configuration.
File Type: jpg a47 discrete rail splitter with crossfeed.jpg (126.0 KB, 108 views)
File Type: jpg a47 off board power with crossfeed.jpg (124.4 KB, 11 views)
Old 5th November 2013, 12:51 AM   #30
Hi Yurk,
How do you connect MNGD to GND/AGND if you use your first design? Can i just hardwire these grounds?
Thanks,
Alexander
Attaching SMD to prototype board is driving me Crazy... DonWarr Construction Tips 2 23rd February 2013 11:22 AM
New CMOY Hewie Chip Amps 6 21st March 2011 10:52 AM
My First DIY Audio Project: A Custom CMoy Test Board. isen78 Chip Amps 9 9th March 2011 01:58 PM
cmoy bb , jds board, self induced woes espressogeek Chip Amps 1 25th September 2008 04:59 PM
CMOY Help? sbelyo Chip Amps 2 3rd July 2004 10:14 AM
Copyright 1999-2017 diyAudio
