Headphone Systems Everything to do with Headphones
YAHA HELP
YAHA HELP
Old 30th July 2013, 09:19 PM   #31
prezden is offline prezden  Canada
Well I have made the changes suggested by dfy and almost got it working. When I turned it on the dim light bulb flared quite bright went off, The regulator got very hot instantly and the right channel on my headphone got toasted.
Fortunately they were cheap earbuds and not good phones
I'm sure I've done something stupid here so once again I will need some help please
Old 30th July 2013, 09:58 PM   #32
dfy is offline dfy
Okay, so a few safety rules first before you plug it in next time:
Power it on without phones or source plugged in of course! Then check DC offset at the output (measure voltage between GND and both channels at the output) before plugging anything in.
As to what went wrong... I re-checked all your pictures again, and it seems you have a large solder blob that connects two traces that shouldn't be and therefore put the right channel of your headphones at +12V DC. See attached picture.
The regulator may or may not be dead after this. There may be more wiring/soldering problems, really do some extensive testing with a multimeter (for connections that shouldn't be there before(!) you turn it on and for sensible voltages after you turn it on, but before you plug in phones or sources).
Old 30th July 2013, 10:31 PM   #33
Hi- I cleaned up the solder on the board. The dc offset is 1.7mv on one channel and .7 on the other. This seems high to me
The LM317 gets very hot in a matter of seconds
Old 30th July 2013, 10:45 PM   #34
dfy is offline dfy
No, those millivolts should be fine as a DC offset. I'm at a loss about the regulator getting super hot though. Either it's dead or there is a wiring mistake that I missed or don't understand correctly. Let's wait for someone else to weigh in on that.
Old 31st July 2013, 03:33 PM   #35
Avro Arrow is offline Avro Arrow  Canada
Avro Arrow's Avatar
Time for some basic troubleshooting.
What is the output voltage from the regulator?
With a 1k and 5k resistor, it should be 7.5 volts.
Even that seem pretty high. the tube should have
6 volts between pin 4 and 5 +- 15%. People usually
use 6.3 volts. If, as you said, the tube glowed very
bright and then went dark, the tube is trashed.
If the regulator is blown and putting out 12 volts, that
will be why the tube is blown.
You mentioned the offsets were 1.7mV and 700mV,
is that correct?
dfy has been giving correct advice. The picture in post 14
is how it should be wired.
Old 31st July 2013, 03:39 PM   #36
Avro Arrow's Avatar
I check my 6922 tube (an ecc88 family version) and have a resistance
of about 3 ohms between pin 4 and 5. Pin 9 is not connected to
the heater circuit.
Old 31st July 2013, 03:40 PM   #37
dfy is offline dfy
is that correct?
Good thing you spotted that. I thought he meant 1.7mV and 0.7mV...
Old 31st July 2013, 03:57 PM   #38
Hi Avro Arrow-
It's not the tube which flared and went out. It's the bulb on my dim bulb tester. Sorry if I said that incorrectly. The dc offsets were 1.7mv and 0.7mv. I will check the other measurements and let you know what I come up with. Last night I put on a larger heat sick and left it on for about 10min and it didn't heat up as much as before; still quite warm though. The tube was glowing steadily while it was on.
Thanks for all your help
Old 31st July 2013, 04:16 PM   #39
Avro Arrow's Avatar
Thats better news to here.
The offsets are fine.
If the tube heater is still glowing then the regulator
is probably fine too.
Old 31st July 2013, 04:25 PM   #40
Avro Arrow's Avatar
A basic rule of thumb for the heat sink is:
If it's uncomfortable to hold on to, you should
have a bigger heat sink.
YAHA HELPHide this!Advertise here!
YAHA with output buffer: need help TB Headphone Systems 3 25th August 2010 04:17 PM
hummming YAHA frajavcar Tubes / Valves 0 1st July 2008 05:58 AM
