whats worng with this circut - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 23rd June 2013, 07:18 AM   #1
Default whats worng with this circut
i am try to simulate it and it dosn't work at all
Old 23rd June 2013, 07:24 AM   #2
Mooly's Avatar
The non inverting opamp input needs biasing to the "midpoint" voltage.
Old 23rd June 2013, 07:27 AM   #3
Mooly's Avatar
There are some other problems too. The midpoint voltage (junction of the 100K's) need to be at a low impedance to AC which means adding a cap across R2, in practice something like 10uf)
Why not set your simulation to have a mid point voltage created by using another voltage source rather than two resistors. That takes the time constant of the cap out of the simulation.
Old 23rd June 2013, 07:33 AM   #4
Mooly's Avatar
Like this,
Old 23rd June 2013, 07:46 AM   #5
not working the output is steady line
Old 23rd June 2013, 07:50 AM   #6
Remove the voltage divider network formed by the two 100K resistors (posters ORIGINAL circuit) from the bottom of R1 and relace with an earth . Place the 100K voltage divider network at the + input after Cin to set the midpoint and bias the + input then the notes still hold good .
Old 23rd June 2013, 07:56 AM   #7
i quit
Old 23rd June 2013, 08:05 AM   #8
Dont you need to have an earth connection at the oscillator to generate the signal across the input to the amp .
Old 23rd June 2013, 08:13 AM   #9
Mooly's Avatar
The circuit in post #5 looks correct although 5 volts is to low for a TL074
Old 23rd June 2013, 08:21 AM   #10
Mooly's Avatar
It definitely works. Just tried it in Spice.
Another Soft Start Circut alweit Power Supplies 0 14th July 2012 08:42 PM
circut card cleaning dognut Parts 7 22nd April 2009 09:04 PM
New to Circut design:help! zolthoff Power Supplies 2 18th March 2007 02:17 AM
Circut bending guitargully Instruments and Amps 4 20th July 2005 08:31 AM
Is This circut suitable for an OPA541? bigmike216 Chip Amps 3 28th April 2005 03:38 PM
Copyright 1999-2017 diyAudio
