Headphone Systems Everything to do with Headphones
Szekeres VE protection diodes?
Old 20th June 2013, 09:13 PM   #1
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Default Szekeres VE protection diodes?
Hello,
I have made a small board to try out Richard Murdeys Szekeres VE design (RJM Audio - Szekeres VE Headphone Buffer) It seems to work fine, but the article mentions using gate protection diodes for the IRF510 FETs. What type of diodes should be used here and what is the correct way of connecting these?
EDIT: I can see protection diodes in the original Szekeres article on headwize, but it is a single-supply design so I am not sure if this will be the same?
/U.
DIY projects blog
Old 20th June 2013, 09:41 PM   #2
Neutrality is offline Neutrality  Denmark
It will work just fine without the gate protection diodes, no need to worry.
I do not want to sound too critical, but such a simple design is recipe for absolutely huge amounts of distortion. Why anyone would want to use such a buffer is beyond my understanding. On top of that it even has some sort of virtual ground going on as well, .
Maybe it is just me that is unable to understand these simple buffer circuits but I just do not see the attraction.
Old 21st June 2013, 07:20 AM   #3
Nisbeth's Avatar
Thanks. I know there are much better circuits out there but I still wanted to try it. When I first joined Headwize more than ten years ago the original Szekeres circuit was one of the designs that was heavily discussed, but I never tried it so there is some nostalgia involved here as well
/U.
DIY projects blog
Szekeres VE protection diodes?Hide this!Advertise here!
DRV134 and protection diodes MavKbds Analog Line Level 2 9th October 2012 02:59 PM
TDA2030a protection diodes PeteMcK Chip Amps 4 28th May 2011 11:14 PM
mosfet amp protection diodes east electronics Solid State 41 16th May 2007 10:54 AM
