Headphone Systems Everything to do with Headphones
Headphone Amp Feels 'Electrified'
Old 22nd June 2013, 04:59 AM   #11
hpeter is offline hpeter  Slovakia
hpeter's Avatar
Originally Posted by roosar View Post
Thanks for all of the quick replies. It does run on batteries or a linear regulated PSU (I've tried both) and I have felt the 'electrified case' when it has been attached to my SACD player (which does only have two prongs for the AC mains) and my Xbox 360 which also only has two prongs even though it still uses a Mickey Mouse plug from the PSU to the wall. I'll try to experiment with some different devices (like my blu-ray player, ps3, etc.) and some different plugs throughout the house...now that I think about it, I remember some of my downstairs outlets did register a ground fault when I tested them upon moving into my house. I'll try one of my good outlets upstairs.
Thanks again,
Robert
(X)Y safety capacitors currents
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H9C+gyrator > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LC 12H/1000
Old 22nd June 2013, 04:53 PM   #12
Fast Eddie D is offline Fast Eddie D  United States
Ground wires are often unhooked by plumbers and then not reattached or reattached improperly. Plumbing repairs can interrupt ground path even if the plumber does not touch the ground wires. My house had this problem when I bought it; a plumber had replaced an iron pipe with a copper pipe attached with plastic bushings. The plastic bushings are to prevent corrosion caused by two dissimilar metals in contact. They also interrupted the mains ground path.
Old 22nd June 2013, 07:15 PM   #13
sgrossklass is offline sgrossklass  Germany
Interesting. I'm not sure whether running mains protective earth (or even return) over plumbing is even allowed over here. Definitely not for gas pipes, that much I know.
And yes, as mentioned this phenomenon can appear when Class II (double insulated) devices are using mains filter caps from phase and neutral to circuit ground. This essentially has ground floating at half mains voltage. Depending on capacitance values, it's also good for some nasty sparks when plugging things in.
Old 23rd June 2013, 06:07 AM   #14
hpeter's Avatar
sure, gas pipes are also here forbidden, anyway gnd wiring should be done separately, not from water pipes.
let electrician check your gnd wiring, we have rule <2Ω to ground
metal cover appliances should have 3pin socket
TN-C or TN-S ?
Old 23rd June 2013, 04:40 PM   #15
It's NEC code here. Only licensed union personnel are allowed to work on electrical, plumbing, and gas lines. In some areas, you have to be in a union to move a chair from one room to another but that's another rant.
Of course, it is the exception that licensed workers repair most houses. It's the difference between $120/ hr and $25/ hr. Very few homeowners are willing to pay the ridiculous price for union work. As a result, union guys don't get much work and "scabs" have more work than they can handle. A lot of union guys are "scabs" on the side of course.
A Three Stooges episode comes to mind.
That's terrible. Everything I build is three pronged and grounded. Ungrounded outlets are obsolete here, but still commonly found. The first thin I did when I bought my house was swap the ungrounded outlets for grounded ones.
My house is grounded to the plumbing (correctly now), but my shop is grounded through two 4 foot long copper stakes driven into the ground.
Old 23rd June 2013, 06:10 PM   #16
RNMarsh is online now RNMarsh  United States
RNMarsh's Avatar
Measure between ground and neutral wire for < .25vac.
-RNM
Headphone Amp Feels 'Electrified'Hide this!Advertise here!
My new el34 + 12ax7 VCT amp. (Need Ideas For my first headphone vacuum tube amp Too~) briansune Tubes / Valves 10 12th July 2013 05:33 PM
recommend me a valve headphone amp - Beyer T1 & AKG Q701 etc gbullimore Headphone Systems 5 18th April 2013 04:39 PM
It feels good to be back! lemans23 Multi-Way 21 18th November 2006 06:02 AM
SDS Labs Headphone amp. Anyone built it? can it be converted to a power amp? JCoffey Headphone Systems 1 30th May 2003 12:11 PM
pot feels broken but measures ok? travis Parts 3 12th May 2003 06:46 PM
