O2 LiPo Daughterboard - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 24th June 2013, 11:51 AM   #21
ryuji is offline ryuji  United States
the tpa6120 consumes a lot more power idle then i please. im going back to o2 style, except i have decided that I am rebuilding it with smd parts at a smaller profile. Focusing on power efficiency.
i think i've decided what to use for smd amp. These seem to be the lowest quiescent current that still compare to original specs of o2
lm7332 will be the output, unity gain and parallel, same output current as stock o2's but 2mA per ic quiescent instead of 8-ish
http://www.ti.com/lit/ds/symlink/lm7332.pdf
RC4680 for the gain stage. cheap, low quiescent. labeled as substitute for 5532. 6 total mA idle
http://www.ti.com/lit/ds/symlink/rc4580.pdf
At a total of 10 mA idle, at 70% switching efficiency(picked worst efficiency off the graph) and +-12v it should consume 342 mW, battery is rated at 7.4 Watt-Hours, so 21 hours baseline, less for regulation/filtering inefficiencies and whatever power is consumed through the headphones obviously.
Goal is going to be to make this as small as possible, and use an appropriate slim/small chassis.
Got quite a bit of free time this week, so progress should be somewhat steady.
Old 24th June 2013, 04:39 PM   #22
The output buffer has pretty nice power ratings for the quiescent power draw but a couple things I noticed when I skimmed through the datasheet was the subpar noise rejection and unless I missed something I didn't see any performance data under 1k ohm. is it rated to drive continuous loads of down to 16ohm?
Old 24th June 2013, 05:01 PM   #23
agdr is offline agdr  United States
agdr's Avatar
That output chip looks like a motor driver or current loop driver. The THD graphs are done with a 100K load resistance. The extra quiescent current of the NJM4556A may be worth it to get some better distortion numbers. The NJM4556A THD graph is specified into 200 ohms, bottom of pg. 3:
http://semicon.njr.co.jp/eng/PDF/NJM4556A_E.pdf
and that is with 30dB of voltage gain. Should be a lot better at unity. The LM7332 graphs are already at a voltage gain of 2, about as good as they will get.
Old 24th June 2013, 05:13 PM   #24
That concerned me too, i thought i would try it out but perhaps with some more looking ill find a better suited one
Old 24th June 2013, 07:26 PM   #25
doesnt really look like there is anything that is able to put out decent current at +-12v other then the NJM4556. plenty of options if i were to stick to +-6v but i believe that would not work so well with 300~600 ohm headphones.
LiPo batteries, help separating facts and myths Peter Pan Everything Else 16 5th February 2012 10:44 PM
Solar powered (charging) circuits with LiPo/LiFe/Li-ion battery Narkki Construction Tips 3 15th November 2011 08:51 AM
LiPO battery charging Atilla Power Supplies 2 4th September 2009 05:37 AM
What DIP plug to use for a daughterboard? leadbelly Parts 1 27th October 2004 07:53 AM
standard daughterboard size for an unsiversal preamp sonnya Solid State 7 9th January 2004 11:33 AM
Copyright 1999-2017 diyAudio
