Headphone Systems Everything to do with Headphones
Home meade design AMP prob's
Old 6th June 2013, 07:17 PM   #1
dobiejoe is offline dobiejoe  United States
Default Home meade design AMP prob's
Help with homemade amp design. I am self-taught and donít use schematics. I just draw out everything as it would be placed on the blank board. The red lines are hard solder wire. The small blues are jumpers soldered to the board. The long blue lines use pins and wires for each output and input needed.
First itís supposed to be an OPA2132 as a Preamp with its output connected to the INíS of a OPA4134. When testing all amps work great on their own but itís when you connect the outputs of the 2132 to the inputs of the 4134 it is nothing but elec noise. I tried a capacitor in line and 1K and 10K resister with no change at all. Any ideas why they work when connected to just one amp on both, but connecting the two does not work.
This picture would be looking down the top side of the amp. INís And OUTĒS with the wires so the placement on the picture is to just show how the L, R, Ground, pots, capís and resisters would be hooked up. Itís a dual RA1 design with one input but two pots so to two outlets can have their own volume
Old 6th June 2013, 09:46 PM   #2
mjf is offline mjf  Austria
not easy to read from this picture......a schematic would be helpful.
lost ground connection between the two amps?
Old 7th June 2013, 06:53 PM   #3
Fast Eddie D is offline Fast Eddie D  United States
Good luck to anybody trying to decipher that. I'm gad it works for the OP though.
Old 7th June 2013, 09:58 PM   #4
Avro Arrow is offline Avro Arrow  Canada
Avro Arrow's Avatar
I'm thinking a ground problem too
Home meade design AMP prob'sHide this!Advertise here!
Forum rookie ? about LM3886 amp prob semi932 Chip Amps 3 10th May 2010 12:04 AM
butler 2150 tube amp prob centexhomeboy Everything Else 2 28th August 2009 06:30 PM
same amp, new prob MTX 8302 LP filter damage Car Audio 8 8th December 2008 03:30 AM
opa549 sub amp prob odysseybmx414 Chip Amps 8 19th May 2005 09:49 PM
Adcom Amp Prob mark_buckles Solid State 3 14th January 2002 09:48 PM
