Dual O2-Inspired, SMD Headphone Amp - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 30th May 2013, 10:27 PM   #11
gastro54's Avatar
And we are live! It "sounds" good - sorry nwavguy But seriously, I need to get this thing measured...
Orthos can be quite demanding. Hifiman HE-6s are pretty notorious, for example. They measured 53 ohms @ 1 kHz and needed 1.0 Vrms or 20 mW for 90 dB SPL.
Those would still make it to a bit over 100 dB on 4 Vrms, though honestly I'd be more worried about distortion at this point. Poor ol' 4556. NwAvGuy didn't even spec the O2 to drive these (though people have apparently reported pretty good results), and that's with twice the output current available.
BTW, 4.0 Vrms != 5.7 Vpp (but rather 5.7 Vp or 11.4 Vpp).
Oh snap. Yes 5.7 Vp, right. Thanks for the heads up on the tough headphones. Thats good info to know sgrossklass.
Bipole Transmission Line TangBand 871s
Old 31st May 2013, 02:03 AM   #12
agdr is offline agdr  United States
agdr's Avatar
I like those battery holders! Pretty neat.
Old 3rd June 2013, 05:05 AM   #13
gastro54's Avatar
I hadn't considered this when I was building the circuit, but as it stands, the turn-on transient is an issue that needs to be addressed. There are differences in the rise time of the positive and negative rails that the battery protection circuit of the O2 guards against.
Originally Posted by RocketScientist
@stockpickerhk, please read the Circuit Description section. The circuit does protect the headphones, and it also greatly reduces the turn on transient every time you turn the amp on. Because the O2 uses a true bipolar power supply, if the positive and negative rails are not perfectly symmetrical on power up and power down, you get a transient at the output. The power circuit reduces that to safe levels.
My mistake. It will be fixed.
Old 20th June 2013, 07:21 AM   #14
availlyrics's Avatar
Originally Posted by gastro54 View Post
I hadn't considered this when I was building the circuit, but as it stands, the turn-on transient is an issue that needs to be addressed....
Hey congratulations, pretty good job! Looks very professional.
According to agdr's idea try pair of 4.7K or 10K(as a bleeder resistor) in parallel with electrolyte cap. to reduce the turn-off transient (if its there). As for turn ON transient I had used 47uF with 0.1uF & toggle switch instead of push-switch for my JRC4556 CMOY with no audible thump.
BTW does those smd JRC4556 gets little warm (no load). I faced thermal issues with smd JRC4556 at +/-7.5V. With +/-5V everything was fine.
Have you(or planning to) published BOM, build-guide, e.t.c. like NwAvGuy?
Thanks,
availlyrics
Old 2nd July 2013, 01:24 PM   #15
gastro54's Avatar
Thanks!
I could try wiring in the 10Ks for the turn-off transient - that would be an easy experiment. Interesting note about the toggle switch. The BOM is in the original post. I wont be doing a build guide for this revision since there are practical issues that make it inconvenient to use. Once I've finished the second revision, I will publish more complete documentation.
The NJM4556AM feel slightly warm, but I don't think its an issue. I used an IR thermometer and the IC temperature never got above 30 C during operation.
Nelson Pass inspired headphone amp Fenris Headphone Systems 42 26th August 2015 02:01 AM
An "O3" - 35% smaller SMD RS O2 headphone amp version agdr Headphone Systems 17 22nd September 2014 02:12 AM
Dual O2-Inspired, SMT Headphone Amp gastro54 Solid State 0 16th May 2013 11:35 PM
FS: O2 Headphone Amp its_bacon12 Swap Meet 1 10th March 2012 04:21 PM
O2 Headphone amp for sale! agdr Vendor's Bazaar 10 9th December 2011 03:05 AM
Copyright 1999-2017 diyAudio
