Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 21st January 2004, 10:22 AM   #81
pjacobi is offline pjacobi  Germany
Send a message via AIM to pjacobi Send a message via MSN to pjacobi Send a message via Yahoo to pjacobi
Fingers faster than brain, sorry to all:
Originally posted by pjacobi
Hi Jam,
The input offset current can be made small with diamond of darlingtons, e.g. 0.3uV in this test circuit:
http://www.linearaudio.de/scratch/dmnd-test-2a.pdf
Best Regards,
Peter Jacobi
That are 0.3uA (micro Amperes), as I was discussing the input
offset current here. This is caused by the beta mismatch, whereas the the input offset voltage is caused by Vbe mismatch.
With 47k at the input, that would give about 14mV offset caused by the beta mismatch. As some extent of this can be considered systematic and unchanging, it can be trimmed lower somewhat.
Per-Anders: Fortunately, when simulating diamonds, you already have some real life mismatches in your calculations, as the NPN and PNP devices aren't identical (if not somebody has 'synthesized' one one model out of the other).
Sorry again,
Peter
YMMV
Old 21st January 2004, 10:40 AM   #82
Peter,
Yes, models of complementary transistors usually are different.
However, that doesn't mean they are reliable. Take some Spice
models of BJTs and plot some of the usual diagrams (curve trace
of IC vs. Vce for different Ib, Hfe vs. IC, IC vs. Vbe etc.) and
compare with the datasheets. Then you will not trust absolute
figures from simulations as much I think.
Old 21st January 2004, 11:14 AM   #83
Hi Christer, All,
Originally posted by Christer
[...] Take some Spice
But if you stay in class A, and well below IKF, and well above Vce(sat) (which can be done in number of applications), you are in a overwhelmingly linear regime. Using the right BJTs of course.
Look for example at the datasheets of the 2SA872/2SC1775
(but lots of small and medium power transistors can be found for this):
- Ic(Vce) is strikingly linear and a ruler and pencil will give you a consistent VAF
- Ic(Vbe) is amazingly linear (on semilog plot), beatiful physics at work!
- hfe(Ic) is linear in technical quality, for some reasonable Ic range.
And for the simple example of the diamond transistor input offset current, the SPICE result can be straightforward manually verified:
Ic is 15mA
hfe of the darlingtons is better than 10000
=> Ib is less than 1.5uA
=> Ib mismatch better than 1uA,
But of course, and I hope that I've stated that myself in every applicable posting, very low SPICE THD results should always be treated as necessary but not sufficent for real life low distortion.
Peter Jacobi
YMMV
Old 21st January 2004, 12:03 PM   #84
Peter,
sounds like you have found some unusually perfect BJTs then, if
what you said was taken from the datasheets. Most BJTs aren't
that perfect and are difficult to model. You are right though that
the model can work rather well in the "linear" region. My experience
after doing some SPice model DIYing is that it is impossible to
make a realistic all-around model. One has to make a lot of
compromises, or at the very best it is possible to tune the model
to behave decently for a specific working point.
Old 21st January 2004, 01:20 PM   #85
Electrons are yellow and more is better!
peranders's Avatar
Default Re: Tinkering around with the QRV06
Hi peranders,
Thank you for posting the LTSpice .asc file (in the "True Current Feedback..." thread), so that I was able to easily play with it.
I've switched back to this thread, as it seems more fitting.
As said, as a first test I substituted the current source for the input diamond with a simple 11k resistor, with no noticable effect on distortion. Both version give 0.0068% THD from the".fourier 20k V(vout)" command.
Peter can you tell me how were your settings for achieving so good distortion figures?
When I make a FFT I don't get so exciting figures.
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 21st January 2004, 02:04 PM   #86
Originally posted by PMA
The simulation results we have for the Jung's buffer are very promissing (THD lowered about 10x).
I just made some quick simulations (well, as quick as it can be to
run extensive transient analysis and FFT). The results agree with
yours, it seem. Using CFP outputs improved the 3rd order harmonic
by 20dB, the others improved but not so much, but the 3rd order
is the dominant one in both cases. It looks promising indeed.
Old 21st January 2004, 02:13 PM   #87
Default Re: Re: Tinkering around with the QRV06
Hi Per-Anders,
Very short answer:
Don't trust the numbers too much. Essentially they all read "very low".
Short answer:
a) Everytime I start LTSpice I disable compression in the Control Panel (once I will learn how to make this permanent)
b) Starting with your .asc, I only added the directive
c) After running the transient analysis, the results are available via "View SPICE Error Log"
Long answer:
To get consistent result in this low THD region is difficult and best assisted by a fast CPU.
More tips:
- To get a better result from the graphical FFT, I'll suggest 65536 points and Hann window.
- Better results for both .fourier and graphical FFT are achieved by shorting input and output C (or using an insanely long "Time to start saving data").
- If you're really desperate to get most accurate numbers, use two E blocks to add output and -4.3 input and analyze the sum (i.e. difference signal). You can refine this technique to something like a software "Klirrfaktormeßbrücke" (don't know the english term).
Peter Jacobi
YMMV
Old 21st January 2004, 02:27 PM   #88
Hi Christer,
[...] Using CFP outputs improved the 3rd order harmonic
I hope we are talking about vaguely similiar circuits...
Getting most of current swing from the added transistors allow all transistors in the diamond to operate at fairly constant current.
This, IMHO, is the main source of improvement.
Depending on your output current needs, it also becomes possible, to have the same transistor pairs in both stages of diamond, and at the same Iq.
For a power output stage this may require actually using darlington outputs, like in this circuit:
http://www.double-diamond.de/scratch/DARL-BUFFER.pdf
Sorry, that one may look confusing, not only because of my lacking drafting talents, but also because the stage is designed to have small gain (4dB).
Peter Jacobi
YMMV
Old 21st January 2004, 02:57 PM   #89
jam is offline jam  United States
jam's Avatar
Peter,
Thanks for your response. Your latest circuit is starting to look like Hiraga's Class A amplifier.
In your original circuit, I suppose the Darlingtons would help and replacing R5 and R6 with adjustable current sources would help adjust bias and offset.
Jam
Old 21st January 2004, 02:58 PM   #90
Peter,
Yes similar but not identical. I don't use Darlingtons and I didin't
add any resistors. I just replaced the output followers with CF
pairs. There should probably be a bias resistor, but I was to lazy
to put it in and it worked fine in the simulations without it.
I have always thought of a CF pair as a CE output stage with
a complementary driver. However, perhaps it is more appropriate
to view the first transistor as a follower output and the second
one just as a kind of current booster? That seems to make sense in
the Diamond buffer case.
four transistor emitter follower (diamond buffer) as power output stage? capslock Solid State 101 15th March 2013 07:25 PM
FS:TI(Burr-Brown) BUF634T 250mA HIGH SPEED BUFFER YFW Swap Meet 2 3rd July 2008 02:15 AM
CFP diamond buffer output stage with vertical FETs, thermally stable? Russ White Solid State 5 1st January 2008 04:16 AM
Diamond Output buffer eats trannies (thermal) blu_line Solid State 50 13th February 2007 08:03 PM
sziklai-darlington diamond buffer (SDDB) for power output stages mtlin12 Solid State 5 1st April 2005 06:55 AM
Copyright ©1999-2013 diyAudio
