Current feedback high speed headphone amp with diamond output buffer - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 4th December 2003, 10:46 AM   #21
Electrons are yellow and more is better!
peranders's Avatar
The soldering iron is hot.... not finished yet... but soon I'll hope.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 4th December 2003, 03:11 PM   #22
peufeu is offline peufeu  France
Default Schematics..
I'd love to have a look at the schematics. Which transistor types did you use to get that frequency response ?
Old 4th December 2003, 03:35 PM   #23
peranders's Avatar
Schematics here and additional info here, not much at the moment.
Transistors are plain BC850C, BC860C (>100 MHz) and BCP53 and BCP56 (130 MHz). The design can take almost any small signal transistor and SOT223 power transistor.
Old 4th December 2003, 03:51 PM   #24
Default Schematics
OK, I see !
Seeing the schematic I understand how you got that performance. It looks a lot like current feedback opamp, implemented in discrete... I've wanted to try this but never got around to it.
So how does it sound ? Did you finish it yet ?
Keep up !
Old 4th December 2003, 04:03 PM   #25
peranders's Avatar
The design is very basic, like the ones you can find in examples of current feedback amp theory, which is available on the net. The rest which I have added can be seen in integrated devices.
I will post results when it's finished. Meanwhile you can check my diamond buffer which has a very nice performace.
Old 5th December 2003, 03:15 PM   #26
peranders's Avatar
The end is near. No smoke so far..... more results will come.
Old 5th December 2003, 05:57 PM   #27
peranders's Avatar
I have tested the amp now and it works, directly from simulation! Distortion seems lower in the real world. It's not significantly different from the soundcard 0.0088% and the soundcard alonde 0.0083% where hum is a part of this.
Step response is excellent. Risetime is much less than 75 ns which my signal generator has.
I haven't tested with my other signal source yet. 1 MHz square wave, 10 V pp is identical with the input signal. Offset only 3 mV out! The other channel has more but I haven't investigated why yet.
The sound is splendid
RightMark distortion analyze files are available, send me a message for the html files. File size around 1 MB.
Old 6th December 2003, 03:32 PM   #28
dann is offline dann  Sweden
Send a message via ICQ to dann
hello!
hej peranders. vad skulle det kosta för mig att köpa ett sådant kretskort av dig ? är mycket intresserad av att skaffa mig en bra hörlursförstärkare
du kan nå mig på dannzig@home.se
Old 6th December 2003, 06:46 PM   #29
peranders's Avatar
Dann, personal questions is best if they are sent to me as a personal message. Besides only Fred knows swedish around here
About your question, check my homepage!
Old 6th December 2003, 06:51 PM   #30
fred was actually "stand in" for the swedish cook in the muppets.........but mostly he was the drummer.....
four transistor emitter follower (diamond buffer) as power output stage? capslock Solid State 114 22nd February 2015 11:51 AM
FS:TI(Burr-Brown) BUF634T 250mA HIGH SPEED BUFFER YFW Swap Meet 2 3rd July 2008 03:15 AM
CFP diamond buffer output stage with vertical FETs, thermally stable? Russ White Solid State 5 1st January 2008 05:16 AM
Diamond Output buffer eats trannies (thermal) blu_line Solid State 50 13th February 2007 09:03 PM
sziklai-darlington diamond buffer (SDDB) for power output stages mtlin12 Solid State 5 1st April 2005 07:55 AM
Copyright ©1999-2017 diyAudio
