Current feedback high speed headphone amp with diamond output buffer - Page 11 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 23rd January 2004, 04:30 PM   #101
I have have done some new simulations comparing the two
buffer types, but I think it is time to follow Pavels suggestion
and start a new thread since we have detoured from the
oriiginal topic. You will see a new thread appear soon.
Moderators: Maybe you should try to split away some of the previous
discussion to the new thread?
Old 23rd January 2004, 05:25 PM   #102
New thread here http://www.diyaudio.com/forums/showt...458#post309458
Old 30th January 2004, 10:53 PM   #103
Electrons are yellow and more is better!
peranders's Avatar
SMD isn't very popular amongst DIY:ers, so this is the first QRV-06 besides my own. Well done Freddie. He has also blue LED's in the corners!
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 110 paid.
Old 20th August 2015, 02:10 AM   #104
jcdrisc is offline jcdrisc  Australia
Remember Peranders most well designed amplifiers have an LPF of 1k/220pf on the input. Excessive amplifier bandwidth is asking for trouble and possible transducer/tweeter destruction. The amplifier is an AUDIO amplifier, not an RF amplifier !!
Old 20th August 2015, 02:18 AM   #105
Yes Hugh you are correct as the interface intermodulation distortion for a compound emitter follower is least. A Wireless World article (by Otala, I think) looked at all configurations and found the compound EF or triple is best. Self supports this view.
Old 20th August 2015, 02:47 PM   #106
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by peranders View Post
Your idea about the name was new
Anyone who really knows, Mr D maybe?
FYI --
[R.Baker of MIT - USA is the inventor of the diamond configuration]
THx-RNMarsh
Old 20th August 2015, 02:51 PM   #107
RNMarsh's Avatar
Originally Posted by Christer View Post
Sounds like we mean the same thing. Below is a picture from
Slones book with his "definition" of CFP. In this case a push pull
CFP output stage. Does this agree with your "definition" of CFP?
If so, I asume we are talking about resistors R1 and R2?
Don't bother about resistor values here, I only follow the topology.
I used more than 100 Ohms, to get the same current as I had
in the CCSs in the first stage (good or bad, I don't know).
........I should probably, for a start, revert back to
simulations with ideal BJT models first and see what difference
the two topologies give in that case, and then go back to real
BJT models, and maybe use other output devices.
I use this OPS configuration in my headphone amp design and it works extremely well in that app.
THx-RNMarsh
four transistor emitter follower (diamond buffer) as power output stage? capslock Solid State 114 22nd February 2015 11:51 AM
FS:TI(Burr-Brown) BUF634T 250mA HIGH SPEED BUFFER YFW Swap Meet 2 3rd July 2008 03:15 AM
CFP diamond buffer output stage with vertical FETs, thermally stable? Russ White Solid State 5 1st January 2008 05:16 AM
Diamond Output buffer eats trannies (thermal) blu_line Solid State 50 13th February 2007 09:03 PM
sziklai-darlington diamond buffer (SDDB) for power output stages mtlin12 Solid State 5 1st April 2005 07:55 AM
Copyright ©1999-2017 diyAudio
