Headphone Systems Everything to do with Headphones
The No Headphone Amp!
Old 10th February 2013, 06:59 AM   #21
keantoken is offline keantoken  United States
keantoken's Avatar
LDRs aren't very linear as resistors IIRC. Why not just use a pot?
Any headphone which has an almost perfectly resistive impedance is basically operating in current-drive due to its own internal resistance swamping out the coil reactance. So those AKG's probably tolerate high source impedances better than most headphones.
On that note, current drive is supposed to be better for speakers, although somewhat more difficult to implement. So perhaps the same could be true of headphones? Just EQ out the impedance curve If you can measure the impedance of your headphones this should be easy. Unless your source impedance changes with volume, then the EQ would wander.
The serious flaws of voltage drive - Current-Drive - The Natural Way of Loudspeaker Operation
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 10th February 2013, 01:15 PM   #22
xnor is offline xnor
xnor's Avatar
Almost any dynamic headphone I've seen is under-damped, so any increase in output impedance makes this just worse.
Ideal output impedance = 0, but the rule of thumb is less than 1/8th of nominal impedance of the headphones.
Some dynamic headphones have a fairly flat impedance response, but that's the exception...
Old 10th February 2013, 02:54 PM   #23
AudioLapDance is offline AudioLapDance  Canada
It reminds me of current drive too. I've played with currentclones and loudspeakers but ... I've been keeping that way of looking at it quiet because it would be confusing to people with less technical knowledge.
Old 10th February 2013, 03:05 PM   #24
***Those with less technical knowledge, please note the 1/8th rule is good technical practice and should not be deviated from unless you know what you are doing.***
NwAvGuy summarizes and gives a practical example:
THE SHORT VERSION: All you really need to know is most headphones work best when the output impedance is less than 1/8th the headphone impedance. So, for example, with 32 ohm Grados the output impedance can be, at most, 32/8 = 4 ohms. The Etymotic HF5s are 16 ohms so the max output impedance is 16/8 = 2 ohms. If you want to be assured a source will work well with just about any headphone, simply make sure the output impedance is under 2 ohms.
http://nwavguy.blogspot.co.uk/2011/0...impedance.html
Almost any dynamic headphone I've seen is under-damped ...
Can you point me towards some data?
Thanks,
Jeff
Old 10th February 2013, 03:37 PM   #25
xnor's Avatar
comparison-beyerdynamic-dt-880-32-ohm-dt-880-250-ohm-and-dt-880-600-ohm-headphones
.. and the countless headphone datasheets you can find on that site. (If the page is empty try another browser.)
Old 11th February 2013, 03:32 AM   #26
Perfect, thanks xnor. I'll get to step response and damping soon, first I want to explore frequency response.
I tried to model my AKG K301 as 300 ohm res peak at 80Hz, dipping to 120 at 2kHz and up to 200 at 20kHz.
(Not in this case because I have no graph but ... what's cool here is that if you produce an electrical circuit that follows the impedance of measured headphones then the electrical circuit is modelling both the electrical and mechanical properties of the phones!)
So ... you start with the nominal resistance 120ohm, then you add a resonator circuit that produces the peak at 80Hz [RLC res, 120+180=300], then you add an inductor to cause the hf lift:
I just opened a Tina simulation and cut out the middle, here's the frequency response for a variety of R series
Basic 2 ohm out for source then totals of 2, 7 [ipod], 10 and 20 ohm [standards], 50, 120 [standards], 500, and 909 ohm.
Nothing significant for the lower output impedances but, of course, my crazy circuit produces a 6.5 dB hump at resonance (assumed 80ish) as predicted by xnor. Also interesting is that crazy old standard of Rout=120ohm (dark grey) produces noticeable boost and phase shift.
Here's TINA
SPICE-Based Analog Simulation Program - TINA-TI - TI Software Folder
And the circuit if you want to play:
No Headphone Amp simulation.zip
Jeff
Old 11th February 2013, 06:54 AM   #27
Blues is offline Blues  United States
Blues's Avatar
...On that note, current drive is supposed to be better for speakers, although somewhat more difficult to implement. So perhaps the same could be true of headphones? ...The serious flaws of voltage drive - Current-Drive - The Natural Way of Loudspeaker Operation
Thanks for the link keantoken...
Some posts of Hifiman HE-6 owners using transconductance (current drive) amps as headamp with great results.
HifiMAN HE-6 Planar Magnetic Headphone
First Watt F1, F1J, F2, and F2J are transconductance amps from NP
FIRST WATT PRODUCTS
Old 11th February 2013, 02:39 PM   #28
Here's a great book from 3 years ago and an inverted current clone from a decade ago!
Current drive is confusing and turns everything 'upside-down'. For those trying to get used to seeing things from a voltage perspective (even if idealized and inaccurate) ...
Such confusions could lead to calls of reprehension preceded by explicit advisions!
Please, let's start another thread!
Old 11th February 2013, 02:42 PM   #29
So does this curve remind anyone of anything:
I mean besides bad design and throwing explicit advisions to the wind.
Old 11th February 2013, 03:28 PM   #30
lcsaszar is offline lcsaszar  Hungary
I read somewhere that the standard source resistance for a dynamic headphone output is 120 ohms. They are designed for this specific source resistance.
http://en.wikipedia.org/wiki/Headpho...tput_Impedance
Last edited by lcsaszar; 11th February 2013 at 03:31 PM. Reason: Found the reference
The No Headphone Amp!Hide this!Advertise here!
2x Gain pure op-amp headphone amp idea Dxvideo Headphone Systems 31 6th August 2017 06:09 PM
My new el34 + 12ax7 VCT amp. (Need Ideas For my first headphone vacuum tube amp Too~) briansune Tubes / Valves 10 12th July 2013 06:33 PM
Tube amp OPT for Headphone Amp? (impedance matching question) rongon Tubes / Valves 21 3rd January 2012 05:20 AM
Poor power output, op amp based headphone amp. dannybeckett Solid State 13 27th September 2010 09:31 PM
SDS Labs Headphone amp. Anyone built it? can it be converted to a power amp? JCoffey Headphone Systems 1 30th May 2003 01:11 PM
Copyright ©1999-2017 diyAudio
