Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 30th January 2013, 09:07 AM   #1
Default full range planar headphones using neodynium magnets
Have started 2 designs using small neo magnets, using the frames of cheap headphones that I have dis-assembled. I am still finalizing the layout of each. The magnets differ in length and thickness. When I have finished the different designs in the same headphone carcass, I will see which is the best. I have another cheap headphone carcass, which I will use for the final design. I just need the inspiration to finish them. Seem to find it difficult to be inspired to finish, seem to prefer bigger planars. It's all in the mind, which little bit is left in there.
HENRY
Old 1st February 2013, 12:49 AM   #2
chinsettawong's Avatar
Go for it!
Old 2nd February 2013, 03:04 PM   #3
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
Watch him go!!
Old 5th February 2013, 10:49 AM   #4
here waiting for pic...
Old 5th February 2013, 10:59 AM   #5
Default work on planar headphones done up to now
VARIOUS PHOTOS SHOWING THE 2 DESIGNS BEING WORKED ON. I HAVE CHANGED THE MAGNET LAYOUT.
HENRY
Old 5th February 2013, 11:05 AM   #6
Default SOME MORE
DITTO.
HENRY
Old 5th February 2013, 11:09 AM   #7
I seem to have lost interest in the headphones at the moment! But these pictures should keep you interested, hopefully.Am rebuilding my 4' x 2' frp at the moment not happy with the resonance.
HENRY
Old 5th February 2013, 11:15 AM   #8
Default SOME MORE
SOME MORE PICTURES SHOWING CHEAP HEADPHONE USED TO TAKE PLANAR DESIGN.
HENRY
Old 5th February 2013, 11:33 AM   #9
nice pic (y)
Old 11th May 2013, 08:05 AM   #10
Default planar headphones.
Have finally built 1 half of my design, it does work, but low volume made it 29 ohms but I will reduce that to 6 ohms or thereabouts. Made it up as I went along very fiddly at this size the other side (right) will be easier to wire up only 2 cable join up.Must get organised, and write more things down correctly so I don't forget what I have done and how!!
HENRY
Full range planar speaker using neo magnets JAMESBOS Planars & Exotics 271 Yesterday 09:14 AM
Portable planar magnetic headphones planarmagnetic Planars & Exotics 3 28th October 2012 12:28 AM
Adding magnets to small full range drivers? BHTX Full Range 5 21st November 2011 07:54 PM
Ribbon or planar headphones Spasticteapot Headphone Systems 42 15th February 2011 07:58 PM
Where to find magnets???For Diy Planar floydturbo Planars & Exotics 8 27th July 2010 10:28 PM
Copyright ©1999-2013 diyAudio
