Pimeta V2 or O2? - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 25th January 2013, 06:46 PM   #1
defi is offline defi  United States
Default Pimeta V2 or O2?
Hi, I'm looking towards my second diy amp project. As usual, cmoy was the first, but now I'm looking for something with a little more punch. I've been looking at the 50-100$ diy range that has the ability to recharge/run on wall plug with two batteries. This has left me with the options of tangent's Pimeta v2 and nwavguy's Objective2. I haven't been able to find information on the notable differences of both and also comparing the two.
My main needs are swappable opamps and option to recharge/use on batteries or wall plug. I don't need them to be portable. The two amps cover these. Could someone help me decide? Thank you.
Old 30th January 2013, 04:35 AM   #2
availlyrics's Avatar
Go for O2, because
- Of the shelf, readily available, thru hole parts(no SMD or boutique parts used)
- Simple yet good objective design.
- Near zero ohm o/p impedance (0.5 Ohms)
- Drives 16-600 Ohms h/p with o/p 7V rms /200mA max with adj. gain
- Employs real gnd (No shaky virtual gnd or 3-ch. gnd "concept")
- Flat audio response - no coloration.
I can go on & on...
I won't list any flaws of pimeta as I don't want to start any "War Of Words"
You can get kits/finished O2 from many good reliable sources like jtktam(audio poutine), swalter(Head n Hifi) or epiphany acoustics right here at diyaudio (also lots of help from fellow diyaudio members, especially moders like agdr).
Thanks,
availlyrics
Old 30th January 2013, 02:11 PM   #3
Limp is offline Limp  Norway
Limp's Avatar
Pimeta is one of those infamous 3-channel designs, isn't it? I'd stay away from those.
Old 30th January 2013, 02:16 PM   #4
Did you ever heard one or are you just recommending something based on something you read somewhere?
Could you state the reasons for what you wrote?
Old 30th January 2013, 02:26 PM   #5
xnor's Avatar
I've owned a Mini3 (also a 3-channel design) a few years ago. Man, was that a disappointment and a waste of money.
Old 30th January 2013, 02:29 PM   #6
Limp's Avatar
No, never heard a PPA/Pimeta, and I have never commented on how it sounds.
The design is flawed, that's all. You do not need me to explain how, it has been done in depth by others, much more qualified than me.
Old 30th January 2013, 07:08 PM   #7
adydula is offline adydula  United States
you can not go wrong with the O2....built several amps, including (2) O2's...its a wonderful design, engineered and is totally transparent....low output impedance etc...
would not hesitate to recommend this as a DIY project.
Good luck
Alex
Old 30th January 2013, 11:28 PM   #8
jcx is offline jcx  United States
the distinction between AMB, head-fi's faddish "3 channel" and a active split supply is very small on the pcb
its usually easy to cut and jump (or lift a pin or 2) to have a single copper path from input singal gnd to output gnd
if the project already has a dual polarity supply you can just not stuff the 3rd "gnd channel" - again add a jumper or 2
Old 1st February 2013, 05:06 AM   #9
NwAvGuy: Virtual Grounds & 3 Channel Amps
I highly recommend reading the whole blog (incl. comments)
Thanks,
availlyrics
Best buffer for PIMETA? slowpogo Chip Amps 41 26th November 2010 07:11 AM
Using LMH6642 as a buffer in PIMETA? TheSeekerr Chip Amps 2 10th July 2008 01:59 PM
[help] pimeta ground buffer heating up jchanhm Chip Amps 0 6th June 2007 05:38 AM
Diamond buffer in PIMETA slowpogo Chip Amps 3 19th April 2007 06:58 AM
Just how good is the PIMETA? slowpogo Solid State 3 8th March 2007 04:40 PM
Copyright 1999-2017 diyAudio
