| Headphone Systems Everything to do with Headphones |
Dear all,
Being a ETI (Electronics Today International) reader years ago as a teenager I had a recolection of a Class A headphone amplifier by JLH that I had not seen the circuit for in a long time. Then I saw this link Headphone Class A Amplifier. The ciruit looks simple, and I should like to build a good headphone amplifier for minimal cost and have an irational desire to have a class A deisgn. This will probably not happen in a short time scale but I would be interested to hear your opinion on this circuit. My questions: Do you think its a good design? If not why not? Do you think I can scale it up to larger powers (Say 20 W) if I like it? Regards Owen |
#2 |
It should work well for a small power amp... The electrolytics in the feedback are a neg. Thx -RNM
#3 |
A BJT version of the F5 !
Even the protection is similar. BUT importantly it has an RC to allow transients peaks to pass !!!!!! JLH is no fool. |
#4 |
Thanks for the feedback, I may look into building it sooner but some other things are more pressing in my DIY like finishing off the subwoofers and some software I want to write/finish.
#5 |
JLH was a great designer, no doubt. But the circuit is not original in the way his class A amp was, I would go for that one with lower power devices and lower rails.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#6 |
I remember this circuit. I have always a bit worried by the direct connection of R2 et R3 to the power supply rails.
| JLH Class A headphone amp from eBay...setting bias/output help needed | jmillerdoc | Solid State | 5 | 27th August 2012 03:27 PM |
| JLH Class A headphone amplifier | jamesfeline | Solid State | 80 | 4th June 2012 07:04 PM |
| JLH Distortion Meter in ETI | SoundOff | Everything Else | 20 | 19th January 2012 04:14 PM |
| JLH Class A headphone amp- where to buy from ? | redmaster | Solid State | 0 | 4th July 2011 02:39 PM |
| JLH Headphone Class A | kacernator | Solid State | 1 | 10th June 2011 08:48 AM |
