Headphone Systems Everything to do with Headphones
suggestion for a 200$ headamp
Old 8th January 2013, 10:50 PM   #11
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
You can build the CK2III for that price. It is a discrete no-global feedback design, with a laid back sound. I've built an LM4562->LME49600 headphone amp design similar to the O2, and it was just too bright and steely for my ears. Extremely fatiguing, although the distortion measured extremely low.
Old 8th January 2013, 11:32 PM   #12
jcx is offline jcx  United States
buying/building different amps because your headphones would benefit from EQ is a losing proposition
see the Carver Stereophile Challenge - Stereophile's professional reviewers couldn't tell a $600 Carver SS amp from their choice of "SOTA" tube amp, in their room, their choice of speakers, music - after Carver nulled his amp against their tube amp, padded his amp's output impedance to match
Headroom high end amps came with a output Z switch - trivial for a diyer to add
Linkwitz shows passive discrete "power" EQ networks for iem...
and you could give a digital EQ a fair trial
Old 1st February 2013, 05:33 AM   #13
availlyrics is offline availlyrics  India
availlyrics's Avatar
Originally Posted by dry joint View Post
The O2 is highly rated but is smd and if pre-made may be difficult to change to a larger volume control.
No, O2 uses through hole components.
Thanks,
availlyrics
Old 21st March 2013, 02:19 AM   #14
roline is offline roline  United States
roline's Avatar
For an inexpensive, simple build consider the glass sand hybrid, low cost and good sounding, can drive 24ohm cans. I'm just using a 24V wallwart power supply now, I have a slow start +-12 volt PCB in design to see if it makes any difference. I currently have about $50 in this project.
GLASS-SAND CLASS A TUBE MOSFET HYBRID HEADPHONE AMP
SO many tubes, SO little time!!!
Old 21st March 2013, 03:33 PM   #15
Redshift187 is offline Redshift187  Canada
Originally Posted by jcx View Post
while "discrete is superior" is an entrenched Audiophile meme - they never placed a "expires by date" on it
O2 is likely indistinguishable in DBT against any other objectively good, flat frequency response, low output Z, low distortion design regardless of technology, within its I,V output capability
but similar chip count composite/multiloop amplifiers, using "better" speced op amps released in the past decade or so are really untouchable at line level audio today - if accuracy is any part of your hifi amplifier definition
isolated bipolar, SiGe, GHz semi processes, advanced internal circuit designs by big companies competing for modern telcom, imaging market applications have taken a big step forward from the era of 4556, 5534
I agree wholeheartedly.
OP: I strongly recommend The Wire, if you can find boards anywhere.
Tyler
Old 21st March 2013, 06:03 PM   #16
adason is offline adason  United States
adason's Avatar
when I have seen the title of the thread, I thought you are asking about preamplifier for the reel to reel head, at least that's what we used to call headamp
Old 21st March 2013, 06:09 PM   #17
adason's Avatar
Originally Posted by cotdt View Post
...it was just too bright and steely for my ears. Extremely fatiguing, although the distortion measured extremely low.
the distortion measurement was most likely not done right... if it sounds bright and steely, than measurements must confirm it...have you done IM distortion measurements? have you looked at 13+14kHz twin tone spectra?
suggestion for a 200$ headampHide this!Advertise here!
suggestion for a 15 inch, under 200$ each that is good from 35hz to 300hz murphythecat8 Multi-Way 34 24th November 2012 02:50 AM
It's my AD815 headamp Kochkurov Maxim Chip Amps 16 11th May 2006 11:44 AM
another chip headamp digi01 Chip Amps 6 23rd June 2004 03:18 AM
Difference between Hertz HS-200 and HX-200 FaZ72 Multi-Way 2 8th April 2004 01:34 PM
Aura Ca-200 / Pa-200 cdl Solid State 8 7th October 2003 12:13 AM
