Headphone Systems Everything to do with Headphones
A47 / Crystal CMoy
A47 / Crystal CMoy
Old 16th December 2012, 05:54 PM   #1
evovil is offline evovil  South Africa
Default A47 / Crystal CMoy
Looking to put together a combination of the two.
Couple of questions...
  1. Think its doable in a freeform/point-to-point form?
  2. Can I run an A47 off of 9V or does it require 18V?
  3. For the power supply, I'd prefer to steer clear of a voltage divider, so TLE2426, op amp based, or Sijosae's method? (buffers are rather expensive where I am so would like to avoid them)
  4. Based off of the schematics I found (below), if I eliminate the pot does anything need to change?
  5. Are those resistor values "decent"? (not 100% sure how to work out the gain in a buffered setup)
  6. OPA2134 or OPA2227 or OPA2132?
  7. In theory, if I were to implement a bass boost via a RC circuit, in which feedback loop would it be placed? Or both? (referring to the schematics)
(all credit due to image creators/owners)
Old 17th December 2012, 10:36 PM   #2
jcx is offline jcx  United States
what headphones? - headphone impedance, sensitivity numbers determines amp I, V requirements
what happened to the O2 build?
Old 18th December 2012, 11:38 AM   #3
Ah yes forgot to put that in...
Sennheiser 558's... so 50 ohm...
O2 build will happen eventually, but probably only next year sometime, so looking to put together something smaller in the mean time
Old 18th December 2012, 03:18 PM   #4
knowing the 112 dB SPL re 1 Vrms senstivity number helps too
these would actually be fine for most listening direct from most DAP which are designed for even lower Z loads already
3.5 Vpk, 70 mA pk would drive them to ~120 dB SPL
single 9V would be fine but you do need to do something re supply splitting or (gasp) output C DC blocking
Old 18th December 2012, 03:35 PM   #5
Output DC blocking?
Thought that was what the input cap was for, to block DC
Old 18th December 2012, 08:44 PM   #6
output coupling Caps let the amp signal ground run from a simple resistive supply splitter
but require large caps to get the low frequncy corner below audio with the low Z load of the headphones
if you follow the recommendations for "best" practice for the application - seriesed non-polar electrolytic, fc ~1/10 the hedphone 3dB point - they end up bigger than the battery for your 50 Ohm headphones - a detraction for portable use
Old 18th December 2012, 09:30 PM   #7
Hmm..
I must say, im rather lost, im not going to lie
Old 6th January 2013, 03:52 PM   #8
tamasic1 is offline tamasic1  United States
tamasic1's Avatar
Default please explain more
JCX,
Are you saying every CMOY type design is flawed because they don't have output caps?
Tube Amp builders - Getter Done!
Old 6th January 2013, 11:49 PM   #9
paulb is offline paulb  Canada
With the circuit as shown, it needs to be powered by a dual (+/-) power supply. If you don't know what that is you should read the headwize tutorials.
Old 8th January 2013, 01:39 AM   #10
tamasic1's Avatar
Default question 3 not answered
Paulb,
Per the OP's original inquiry, question # 3 is asking:
So he's pretty much read all about this. Instead of giving him a drive by condescension, why not give him you insight to the methods you have tried???
A47 / Crystal CMoyHide this!Advertise here!
Crystal? slideman82 Everything Else 6 18th February 2012 11:19 AM
New CMOY Hewie Chip Amps 6 21st March 2011 10:52 AM
What crystal is this?? calvinhpk Digital Source 4 24th August 2009 03:08 PM
What crystal is these? calvinhpk Parts 6 24th August 2009 07:35 AM
CMOY Help? sbelyo Chip Amps 2 3rd July 2004 10:14 AM
