Headphone Systems Everything to do with Headphones
The DAO SE all-FET Class-A ZGF Headphone Amplifier
Old 23rd December 2012, 01:07 PM   #51
Telstar is offline Telstar  Italy
Originally Posted by EUVL View Post
A version of the DAO as it is will do 11Vrms and 150mA.
It will be described in Part 2b of the article (after Xmas).
So I consider the AKG 600 covered.
The HE-6 I also now considered solved, at least in simulation, using 5 active devices per channel.
The driver device is still an LU1014, cascoded by a higher power MOSFET.
The trick is then to get the LU1014 to work in triode mode at a bias of ~500mA.
In simulation, at full +/-25V swing into 50 ohm load, 2nd harmonics is -85dB, 3rd -100dB, 4th -105dB.
Bandwidth -3dB is 2MHz.
That is respectable performance, even only in simulation.
The changes are not minor, so we need new PCBs as well as a substantially revised case design.
But since headphone is not our main interest, I doubt we should invest 1300 USD to buy one of these just for testing.
Unless of course there is a huge interest (so far only you ?).
2
But i'm interested in lower voltage, higher current to drive 25-80 ohm HPs only.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 23rd December 2012, 01:54 PM   #52
buzzforb is offline buzzforb  United States
buzzforb's Avatar
In the spirit of DIY, have you considered figuring it out on your own, following EUVL's wealth of given info.
...Shape the sound , Man!
Old 23rd December 2012, 02:21 PM   #53
EUVL is offline EUVL  Europe
How do you define "high" current ?
Is 200mA Class A insufficient ?
The original DAO was designed for the AKGK701 at 62 ohm, which is about the middle of your mentioned range.
On top of that, I have not finished published all parts of the article.
For example, in Part 2b, higher current and higher voltage versions would be dealt with.
The HE-6 is a special case.
I do not know any other headphone that needs 6W, other than maybe the electrostatics.
That is why it needs special treatment.
Maybe a bit more patience, and your "problem" might be resolved automatically.
Merry Christmas,
Patrick
xen-audio.com
Old 24th December 2012, 06:15 AM   #54
Some more reading material for Christmas.
Patrick
xen-audio.com
Old 24th December 2012, 12:42 PM   #55
I don't have any problem
Good reads I have for Xmas day.
Old 28th December 2012, 09:32 AM   #56
I have been asked to show a simulated FFT plot of the HCLI (High Current Low Impedance) version as described in Part 2b.
Here it is, with 22V p-p output into 40 ohm.
I consider harmonics < -80dB at such output levels to be very respectable for a headamp.
Especially achieved just by a JFET source follower with ZGF.
Patrick
xen-audio.com
Old 29th December 2012, 02:20 PM   #57
And for those interested in the high power version for the HE-6, here is a plot of the 500mA triode cell.
Patrick
xen-audio.com
Old 6th January 2013, 11:36 AM   #58
Patrick
Hmmm
Can you post a plot with 4V output?
Old 6th January 2013, 02:20 PM   #59
It is only simulation.
Better wait for real measurements.
Patrick.
xen-audio.com
Old 20th January 2013, 03:33 PM   #60
Part 3 of the article, plus a couple of finished PCBs.
In case you wonder why the amp PCB has not been shown, I have been waiting for PRP resistors from the US for 2 months !!!!
Patrick
xen-audio.com
The DAO SE all-FET Class-A ZGF Headphone AmplifierHide this!Advertise here!
Midgard, a low distortion Lateral FET output Headphone Amplifier Neutrality Headphone Systems 8 14th December 2012 07:31 PM
Thor, an all discrete Lateral FET Headphone Amplifier. Neutrality Headphone Systems 163 5th November 2012 02:53 PM
WTB: DAO follower headphone amp board/parts/kit/complete korchha Swap Meet 4 5th November 2012 03:37 AM
Mj°lner, another all discrete Lateral FET Headphone Amplifier Neutrality Headphone Systems 13 13th October 2012 07:42 PM
DAO Follower vs F3 Headphone Amp Melon Head Headphone Systems 13 10th November 2009 05:45 PM
Copyright ©1999-2017 diyAudio
