The DAO SE all-FET Class-A ZGF Headphone Amplifier
A few people sent PMs asking for Bill of Materials for the circuits.
Firstly I have, as an exception, already posted component values in the schematics.
But they should be treated as provisional, and will only be finalised after we have completed all build and tests ourselves.
This will help us and you, to avoid confusions due to multiple revisions.
From our experience from the F5X and the Joachim Gerhard projects, we have also decided only to publish final schematics and BoM at our own website.
This will allow us full flexibility for Version control and editing.
So I can only ask you to kindly bear with us for now.
When we are ready to publish them, we shall put up announcements here.
Thank you for your interest,
Patrick
At last some further progress to show. Tests to follow.
Space on top is reserved for the HAGS which is still waiting for PRP resistors as well as FETs matching.
Patrick
Some test results :
Current configuration is DAO standard, bias 195mA.
10kHz square wave with 56R load is perfect without any overshoot.
Gain is 0.876, in line with expectation (Load = 56R, Zout = 7.8R, of which 6.8R is pure resistive.).
DC offset 4mV.
Also as expected some load is required for stability.
For headphones with high impedance, especially at HF, a Zobel of 27R 10nF will ensure perfect response.
Next steps would be to add TCs and HAGS module.
Patrick
Took a bit longer than I wanted, but HAGS is finally tested.
Without any trimming, initial DC was 160mV.
After one trimming resistor (calculated value), DC was down to less than 4mV at steady state.
Cold start value was about 15mV, but this settles to near zero after 3 minutes.
Bear in mind that the DAO following the HAGS is unity gain, and 10mV is 1.5µW for a 65R headphone, I do not consider servo necessary.
Attached also square wave response for 10kHz and 100kHz, as well as frequency response to 2MHz.
-3dB is at about 1MHz. So performance meets expectation.
(Green is input, cyan output.)
Patrick
Hi Patrick, just beeing patient and keeping a very keen eye out.
Just a query - on post #64 back in Feb, you mentioned that you were using the "Standard DAO" at 195mA - Is this the previous non-Taylored version with the IRFP fets or is this pushing the smaller 2sk/j units well above the 100mA detailed in the design sheets?
