Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 10th December 2012, 12:57 PM   #1
Default Background noise - tube amp
As a newbie I ordered this tube amp kit: Under $25 00 DIY 12AU7 Valve Cmoy Hi Fi Headphone Amplifier Kit Guaranteed | eBay
I've finished it and it's working but there is a lot of background noise.
From what I've found here in the forum it could be the AC-adapter.
It's a regulated 12V / 1A adapter but i still making lot's of background noise.
Tried 2 different ac-adapters I had at home, one from Netgear and one from Yamaha.
Could it be something else or is it most likely the ac-adapter?
Can I build some sort of filter?
Can run it from two 9V batterier in series instead?
I haven't fitted the pcb in a case yet but would this do any difference?
Thanks in advance!
Old 10th December 2012, 03:46 PM   #2
merlin el mago's Avatar
Why you don't make a linear PSU for it?
Old 10th December 2012, 04:17 PM   #3
jerluwoo's Avatar
Since this has a lm317 regulator on the board already, changing ac adapters will have no real effect. What is said about the ac adapter being regulated is misleading as very few actually are. I would think it is meant that the adapter rating is 12v 1a, its not necessary for it to be regulated with a regulator already a part of the circuit.
A schematic would be very helpful in finding ways to make it quieter.
Old 11th December 2012, 07:19 AM   #4
How would I make linear PSU?
I will scan the schematic and post it later, no scanner at home.
TSE 45, how do I remove background noise cotdt Tubelab 14 8th November 2012 06:50 PM
LM3886 background noise weatherlight Chip Amps 0 14th May 2008 10:18 AM
Background Noise (Hiss) -- How to Trace jandrusor Solid State 5 25th March 2008 07:47 AM
Background-noise in my new amplifier whee Solid State 1 11th May 2004 12:47 PM
My First Gainclone have background noise Felix Chip Amps 22 9th January 2004 08:46 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
