| Headphone Systems Everything to do with Headphones |
Can the LM386 be used as a headphone amplifier? Would I have to set the gain below 20 to do that, and is that even possible? Or would I have to use a resistor on the input or something? I don't need a volume conrol, since the audio out of the CD player is controlled.
#2 |
Yes, it will work.
But don't expect good sounding
#3 |
No, the LM386 can't be set to a gain below 20. This is way too much for a headphone amp. There are definately better options.
Because of the relatively low power and gain involved in a headphone amp, you are probably better off using a standard op-amp.
#4 | |
#5 | |
#6 |
I suggest you use a OPA627 or OPA637 with a BUF634 after it. The OPA will give the necessary voltage swing, and the BUF634 gives enought current (250mA).
Instead of the (in comparison to the LM386) rather expensive OPA627/637 you could also use the NE5534, which is cheaper and sure good enough if you planned to use the LM386 at first. Grtz, Joris |
#7 | |
#8 |
Yessssssssssssss.....
![]() Grtz, Joris |
#9 |
Hi all,
just for info, older professional cass Tascam 122mkII uses LM386. Newer professional products from Tascam (MD801, DA30,..) use LA6510 power opamp in headphones amp. http://62.236.156.23/ideaport/d/la6510.pdf Regards |
| Lm386 | frenchie29 | Chip Amps | 10 | 27th April 2009 09:32 PM |
| Need some help with DAC and LM386 | zhane | Chip Amps | 6 | 21st April 2008 07:38 PM |
| LM386 Headphone amp - static | zenon | Headphone Systems | 26 | 30th May 2006 05:06 AM |
| Will this PSU work? (from Dynahi headphone amp) | bg4533 | Headphone Systems | 1 | 30th December 2004 12:32 AM |
| LM386 but on AC? | tubbytwo | Chip Amps | 6 | 29th November 2004 12:38 AM |
