Headphone Systems Everything to do with Headphones
Balanced input headphone amp
Old 26th November 2012, 01:13 AM   #1
homik is offline homik
homik's Avatar
Default Balanced input headphone amp
Hey all! After stalking the DIY Audio forums for a few years, I finally have something to show for myself.
I'm putting together a headphone amp and I wanted to take advantage of my DAC's balanced outputs, so with a little research and tinkering I came up with this design. There are a few things that I'm going to change in the final design, but this is the gist of it.
- The values shown have it set to unity gain which i may tweak, but my DAC puts out 2Vrms so i doubt i'll need any gain.
- I'm going to use IRF510/IRF9510 output MOSFETS. The schematic shows IRFP240/9240 as those were the only complementary pairs i could find in LTSpice. I will adjust the Vbe Multiplier and bias current in the final design.
Now a few questions for those of you out there who now what they are doing (I'm a second year EE undergrad, so my knowledge is a bit limited):
-Is there anything blatantly wrong with this design? It may not be the most effective design, but it's relatively simple and uses parts that I have.
-What bias current should I use? I have a pair of Grado SR125's, 32Ohm. I've seen bias currents all over the place, even as high as 100mA.
- Any suggestions for better output mosfets? I've seen irf510's used fairly often and have played with them a fair bit myself, and am pretty comfortable with them, but I've also seen all sorts of exotic things used on this forum so I'm open to suggestions.
Schematic:
If someone would like I can post an FFT plot.
Old 26th November 2012, 02:41 AM   #2
jcx is online now jcx  United States
you can attach the .asc to your post as well for people to poke at
you can zip your added device models, or just put the defs on the schematic with the spice directive cmd ( .op far right on tool bar )
mosfets require a fair amount of bias, parasitic capacitances behave poorly when they have < ~ 2x Vt across their D-S so I would use higher supply V even though Grado headphones don't require that much V
I expect the amp is ~ single pole compensated by the parasitic C of the output devices - which as I mentioned is a function of D-S V - it can work but may make the amp very sensitive to parts choice, operating point - and the mosfet spice models may not show this very well
Old 26th November 2012, 06:16 AM   #3
qusp is offline qusp  Australia
qusp's Avatar
i've been informed by grado lovers that they love current source amps and reasonably high output Z....
Old 26th November 2012, 02:38 PM   #4
homik's Avatar
Here's the .asc
I included the 2sk170 as a directive, everything else should be in the standard LTSpice library.
Unfortunately I'm limited by supply voltage, since I already have a 2x 12V toroidal transformer and don't have money for a different one (ah, the life of a student). I know the rectified voltage is higher and all, but with rectifier losses and regulator drop I'm not sure how much higher I can get the supply voltage. I've used irf510's at 12V before and they didn't present much of a problem. With careful layout I think they'll be fine.
HeadAmp.zip
Balanced input headphone ampHide this!Advertise here!
Balanced OTL headphone amp joefish Headphone Systems 0 23rd May 2012 09:26 AM
Balanced Headphone Amp: OPA1632, TPA6120 sek Chip Amps 13 10th July 2011 12:00 AM
Balanced input headphone amplifier Mr. Triatic Headphone Systems 24 13th February 2011 06:53 PM
F4 balanced mono headphone amp khundude Headphone Systems 2 17th December 2008 10:31 PM
SoZ balanced preamp as headphone amp akira Headphone Systems 5 7th January 2002 08:40 PM
