Headphone Systems Everything to do with Headphones
how to mix sound from notebook and external sound card and get headphones output
Old 17th November 2012, 11:18 PM   #11
burence73 is offline burence73  Serbia
Sofaspud,
I add few details on your schemo. I'm not sure about pin 4 of second NE5532. Do I need to connect this pin to -12V or to the ground?
Please advice.
Old 18th November 2012, 06:38 AM   #12
sofaspud is offline sofaspud  United States
sofaspud's Avatar
If using two 5532's, pin 4 of both will connect to -12V. And connect the fourth unused op amp as per this page.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 18th November 2012, 08:01 AM   #13
could you please recomand resistors values (first picure on suggested link). Thank you for effort.
Old 18th November 2012, 08:19 AM   #14
sofaspud's Avatar
Two more of the 10k resistors will be fine, but you don't really need the resistors. Just connect the + input to ground, and the output back to the - input.
Old 18th November 2012, 08:55 AM   #15
thank you
Old 29th December 2012, 01:50 PM   #16
Sofaspud,
Can I use 9V power supply instead 12V for schematic that you suggested to me?
Old 29th December 2012, 02:41 PM   #17
DUG is online now DUG  Canada
This would keep the stereo on the stereo signals.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 29th December 2012, 07:58 PM   #18
sofaspud's Avatar
Originally Posted by burence73 View Post
Sofaspud,
Yes. This information and more can be found in the datasheet.
how to mix sound from notebook and external sound card and get headphones outputHide this!Advertise here!
DAC or External Sound Card pforeman PC Based 2 11th December 2011 05:16 AM
External sound card spot PC Based 6 28th September 2011 09:19 PM
Which DAC / External Sound Card from this list? rg12 Digital Source 0 5th September 2010 10:26 PM
Convert sound card to external DAC Zdman Digital Line Level 0 17th November 2008 02:01 PM
notebook sound card blue934 Digital Line Level 8 28th October 2008 12:29 AM
Copyright ©1999-2017 diyAudio
