Any point in adding a audio transformer for more power? - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 31st October 2012, 01:30 AM   #1
Default Any point in adding a audio transformer for more power?
H! I have a Bravo Audio hybrid tube amp with transistor output.. I would like to get some more output from it into some 4ohm high sensitivity speakers.
Atm it has almost enough output level to drive the speakers at at nearfield listening levels. So I was wondering if I could use an audio transformer to boost output a little? And perhaps skip the DC blocking cap at the output?
Thanks for any replies!
Schematic: (It uses 24V,not 12V.) http://i30.photobucket.com/albums/c3...12au7/shem.png
Also found on Ebay, EI-14 Audio Output Transformer 1K:8 to 32 ohm.
Old 31st October 2012, 04:33 AM   #2
DUG is offline DUG  Canada
Based on R8 (and R10) values of 47R, you would get maximum power with a 47 ohm to 4 ohm transformer.
If the drive circuitry (Q1/IC1) was able to drive the 47R by itself (voltage swing not limited by load) and assigning a 100% efficiency to the 47R:4R transformer, then you would get 5.4dB increase in power to a 4R speaker using the transformer compared to driving it direct.
The transformer would need to have a 11.75 impedance ratio and the one you selected is greater than 30 (1000/32)
It would also need to be rated for about .3W
good luck
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Custom made Audio Power Transformer DIYspaceW Swap Meet 0 5th March 2012 02:44 PM
F5 Point to Point Power Supply Schematic bassnkeys Pass Labs 15 22nd February 2012 04:32 AM
Transformer substitution on a audio power amp. beppe61 Power Supplies 20 28th October 2005 07:49 AM
Audio Note's Kit One done in point-to-point wiring Wram Tubes / Valves 18 29th April 2003 10:59 PM
What makes a good audio power transformer? nania Solid State 94 29th April 2003 02:27 PM
Copyright 1999-2017 diyAudio
