Upgrading ICs in headphone amps - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 26th September 2012, 03:36 PM   #11
jcx is online now jcx  United States
according to Sennheiser HD414 - Wikiphonia the HD414 part number has been used for versions with an order of magnitude different Z
I reccomend more recent chips, benefiting from the complementary processes, advanced linearity internal designs sparked by the DSL, medical imaging markets that have improved specs even further in the last decade - if improved specs are the goal
Old 26th September 2012, 08:28 PM   #12
There are many differences. The TLE2072 has a -/+ 80ma output capability (per opamp in the dual package) which puts it way ahead of the competition.
Slew rate of around 35V/us, a wider operating voltage range..
yet they sound identical
Old 26th September 2012, 08:51 PM   #13
Originally Posted by Mooly View Post
Not so
Slew rate of around 35V/us, a wider operating voltage range.......
While you are at this, why not try TLE2062 which are rated to drive 100-Click the image to open in full size. Loads?
Old 26th September 2012, 10:07 PM   #14
batty is offline batty  Australia
Maybe I should change the thread to extreme chip rolling, I am on limited budget so I take time to get around to these thing, just got a small tax refund so went for 3 options and thought I'd ask the question, original ic was a 353 in the Cmoy kit, can't remember what was in the Oatley, but the Oatley sounds better with the AD823 and the Cmoy better with the 2134......... so far
These are my 414s
HD414 50th Anniversary Edition
Released in 1995 to the 50th anniversary of Sennheiser GmbH & Co
[edit]
Technical specifications
Frequency Response: 18-21000 Hz
Type: Dynamic, open
Impedance (Nominal): 52 Ohms
Sound pressure level at 1 kHz: 94 dB +/- 2 dB
THD as per DIN 45500: < 0.9 %
Contact Pressure: ~2.8 N
Weight (without cable): ~80g
Connector: 3.5 or 6.3 mm (1/8" or 1/4") stereo jack plug
Connection cable: Oxygen Free Copper cable, 3m
Townshend Rock II, My new TT since 1986.
Old 26th September 2012, 10:21 PM   #15
How about the humble JRC4556? RS did a review of an ebay cmoy fitted with it at 1x gain, performed quite well. Plus they do a good job in the O2.
Listening with Gusto!
Old 27th September 2012, 02:41 AM   #16
if I were building an amp for those numbers I would aim for clipping free 120 dB SPL peak drive
thats for dynamic headroom - not for continuous listening, I think the O2 design discussion ends up claiming ~110 dB is adequate so less could be acceptable to some
the 120 dB SPL dynamic peak clipping free goal would require ~ 7 Vpk, 140 mApk - it unlikely any amount of 20 yr old DIP op amp rolling will get you there - you have to choose the few parts or added buffers that can do it
Old 27th September 2012, 03:02 AM   #17
qusp is offline qusp  Australia
qusp's Avatar
yes, well despite having myriad explanations for it, the O2 is not clipping free
Old 27th September 2012, 06:53 AM   #18
Mooly's Avatar
These are more of a micropower opamp which would be great for battery life. AC performance is much lower for these though although they could be very useful in some projects.
Panasonic DVD-H1000 op amps worth upgrading? dkhsu Digital Source 10 9th April 2016 08:10 AM
headphone amps vs headphone inputs? awangotango Headphone Systems 7 13th October 2012 01:36 AM
Upgrading/repairing vintage amps jooch Solid State 22 24th December 2011 02:54 PM
Upgrading op amps in a Denon DCM-460 CD player stank0 Solid State 0 18th January 2010 05:47 PM
Need some advice rebuilding/upgrading 2 power amps. SuperKris Solid State 31 26th May 2009 04:24 AM
Copyright 1999-2017 diyAudio
