resistors in cmoy
They are all standard values. What you need to do, though, is match the gain resistor values so you maintain channel balance, eg if R3 measures 1012Ω on both channels but R4 is 9600Ω on one channel but 10400Ω on the other, you'll have more gain in one channel.
connection
the connection are good?
is the first time that i soldering ic's
i will answer only in on Monday
im planing to build a cmoy amp from this schematics
How to Build the CMoy Pocket Amplifier
for start
now here in Israel is apparently is hard to get 1% resistor
if i take 5% resistor on all of the circuit how awful it will be?
or i make a effort to find a 1% resistor?
i will using the opa2107AP
I am also interested to build a CMOY for my Grado MS1i.
However, I can't find information from the website you post. Can anyone give me some more detail?
Many thanks.
