Headphone Systems Everything to do with Headphones
How do I Improve bass handling in a headphone amp?
Old 22nd September 2012, 02:27 PM   #21
doulos24 is offline doulos24  United States
xnor no I haven't tried that. I built a 12au7/irf510 tube amp and just tsested it yesterday and it's more of what I was looking for. It's about in the middle of the cmoy and the interface in response and I'm petty happy with it as I now have a few options. I will try adding a series resistor and let you know how that goes.
Old 24th September 2012, 08:54 PM   #22
PlasticIsGood is offline PlasticIsGood  United Kingdom
PlasticIsGood's Avatar
The differences you are seeing can be entirely explained by measuring the impedance of the phones at around 100Hz.
The higher the impedance of the driver, the more everything will disappear except the bass. To compensate, you will need a driver able to deliver more clean volts.
Perhaps if you looked at the phones' characteristics beforehand? Perhaps if you showed the circuit of your amp?
If you find a valve makes an improvement, you may be better off with phones not designed to make every note sound like a power chord.
Old 25th September 2012, 12:35 AM   #23
If that is true then how can you explain that the built in amp has the highest bump in the response and external amps have less
If it were the impedance wouldnt all amps exibit the same bump?
What makes more sense is it's the high output impedance of the line outs since the internal amp is not effected by the output it appears diffrent to the external amps. which are much more closley matched
Old 25th September 2012, 01:59 AM   #24
Did you measure? Do you know the output impedance of each of the amps you have driven the phones with. Did you try a resistor in series?
Consider Ohm's Law.
What "makes more sense" to you makes none to me. Perhaps it's just a punctuation thing.
We speak the truth.
No circuit, no impedance characteristics, no further comment.
Old 25th September 2012, 05:26 PM   #25
xnor is offline xnor
xnor's Avatar
It's the combination of both: the impedance curve of the headphones and the output aka source impedance.
As I said before, the profire 2626 has an output impedance of 75 ohms. Your cmoy is probably close to 0 ohms.
The K240 studio has a nominal impedance of 55 ohms and about 160 ohms at 110 Hz.
Old 25th September 2012, 09:33 PM   #26
I'm measuring the output impedance
fast track pro 20 ohm
chu moy 3 ohm
12au7 2 ohms
Old 25th September 2012, 10:04 PM   #27
Fast Eddie D is offline Fast Eddie D  United States
The point that the community is trying to make is that the impedance of the headphones is not constant with frequency. Neither is the output impedance of a tube amp (and to a lesser degree a solid state amp). All this affects the frequency response of the system.
Sometimes a series resistor can compensate for impedance induced frequency response variations. Maybe you could experiment around a little bit. Some guys have a rotary switch on their headphone amps to provide a variety of output resistors for use with different cans.
Old 25th September 2012, 10:20 PM   #28
Interesting thanks for the reply I figure I'll just make more amp design types till I find my favorite more fun that way
How do I Improve bass handling in a headphone amp?Hide this!Advertise here!
How to improve bass response? NVD33 Solid State 70 7th April 2014 10:10 AM
how can i improve this headphone amp bluegrass Solid State 3 29th March 2011 02:50 PM
Please help me improve my headphone amp diego6339 Tubes / Valves 35 2nd December 2010 02:24 AM
Bass amp for Headphone ideas? twenty Headphone Systems 6 19th March 2009 01:14 PM
Bass guitar headphone only amp oldhernace Headphone Systems 1 14th July 2005 04:33 AM
Copyright ©1999-2017 diyAudio
