| Headphone Systems Everything to do with Headphones |
I have built a grado ra1/chu moy stlye headphone Amp. I'm using a dc to dc converter to get a voltage boost and proper balancing rather then dealing with dual 9v batteries. I have added a opamp voltage power rail splitter and changed the psu caps to 470uf the Amp measures very well but it's bass shy compared to my headphone outputs on my pro audio interfaces. how do I measure the headphone handling so I know what to adjust in a diff headphone amp design so I can have a similar amp to my audio interfaces when I'm on the go?
here is my voltage splitter ![]() here is what I'm getting out of my fast track pro ![]() Frequency response (from 40 Hz to 15 kHz), dB +0.05, -0.04 Excellent Noise level, dB (A) -100.3 Excellent Dynamic range, dB (A) 100.3 Excellent THD, % 0.0010 Excellent THD + Noise, dB (A) -92.2 Very good IMD + Noise, % 0.0031 Excellent Stereo crosstalk, dB -86.2 Excellent IMD at 10 kHz, % 0.0035 Excellent Last edited by doulos24; 11th September 2012 at 06:00 PM. |
#2 |
#3 |
How about a fake load (102 Ohm?) and measuring voltage across it using a voltage divider as input to your sound card, then use some frequency plotting software.
#4 |
that might work thanks
#5 |
I don't think that FR measurements with a fake load will help you w.r.t. the bass.
Almost all headphone outs on audio interfaces have a high output impedance, such as 20, 50 or even over 100 ohms. This reduces the damping factor which has a couple of negative effects (FR variations, higher THD ..). Since most dynamic headphones have a resonant frequency around ~80 Hz the headphone driver impedance also rises and has a peak there. The output impedance of the amp and the load impedance work like a voltage divider. This will cause a bass boost. (Actually, the output impedance will attenuate the resonant frequency less than other frequencies where the load impedance is lower.) If you still want to increase the output impedance instead of using an EQ: just put a resistor in series with each headphone driver. Last edited by xnor; 13th September 2012 at 11:49 PM. |
#6 |
Better to use a genuine dual-rail supply than one of these voltage divider 'virtual earth' arrangements, especially one built with a 741.
The 741 doesn't have a lot of slew rate to keep up with whatever opamps you're using for the amplifier proper and it doesn't provide much current. Both of these are considerations. You need twice the current of a single channel. The '3rd. channel' designs are pretty much discredited. Even when properly implemented they contribute crosstalk and distortion. You'll get much better results with a proper dual-rail supply, even if it's only a couple of rechargeable 9V NiMhs. You can build a dual-rail supply with a single AC wallwart. 12V 500mA or better will do. Preferably a little bit more than 500mA. Use 2 NJM4556 opamps in parallel (1 dual) for each channel of your cmoy. Put a 16 ohm resistor across each channel when doing your RMAA measurements, this will show the design at its worst likely performance into headphones. Few headphones are < 16 ohms, 16 ohms is not uncommon though. |
#7 | ||
#8 |
#9 | |
2. Your measurements are almost certainly wrong. Read this page of this blog:- NwAvGuy: Virtual Grounds & 3 Channel Amps. 3. 16 ohms is generally taken as a standard, being the lowest impedance commonly encountered in 'phones. 4. Your picture is unnecessarily big, wastes bandwidth and is so blurred as to convey no useful information whatsoever. |
#10 | |||
no useful information? in ear plugs with omni mic elements attached so I can measure the headphones as i wear them. Last edited by doulos24; 18th September 2012 at 09:27 PM. |
| how can i improve this headphone amp | bluegrass | Solid State | 3 | 29th March 2011 02:50 PM |
| Please help me improve my headphone amp | diego6339 | Tubes / Valves | 35 | 2nd December 2010 02:24 AM |
| How to improve bass response? | NVD33 | Solid State | 64 | 11th November 2010 03:06 PM |
| Bass amp for Headphone ideas? | twenty | Headphone Systems | 6 | 19th March 2009 01:14 PM |
| Bass guitar headphone only amp | oldhernace | Headphone Systems | 1 | 14th July 2005 04:33 AM |
