How do I Improve bass handling in a headphone amp? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 20th September 2012, 01:53 PM   #11
xnor's Avatar
Originally Posted by doulos24 View Post
I used 56 ohm as my headphones are 55 ohm I also have 300 ohm phones
What headphones are those, AKG 240 Studio? Those are not very bassy if properly driven.
Have you tried the resistors in series to raise the output impedance? It should boost the bass similar to what your audio interface's headphone jack does but actually affects sound quality negatively.
Old 20th September 2012, 02:20 PM   #12
they are are consistent with RMAA and when using voxenngo span and room eq wizard with an outside signal generator
Your measurements are almost certainly wrong.
Old 20th September 2012, 09:54 PM   #13
yes they are the k240 studios
Old 20th September 2012, 10:01 PM   #14
when you want to do a scientific measurment it's good to have a control to test against ,so when I Measure my headphone output on my interface it measures exactly as it says it should, but somehow my measurements on my amp are wrong?
let's do the math op amp thd .0008% a few top of the line passive components 1% resistors double sidded pcb meaure thd + noise about 4 times the opamp's self noise .0026% seems about right to me
from the same guy you sent a refrence from measuring a cmoy amp
Frequency Response+/- 0.1 dB ExcellentTHD 1 Khz 150 Ohms0.002% ExcellentTHD 1 Khz 15 Ohms0.030% GoodTHD 20 hz 15 Ohms0.028% GoodTHD 20 Khz 15 Ohms0.040% Very Good
Old 20th September 2012, 10:36 PM   #15
my bad I got the numbers wrong the thd of the chip plus noise is 0.00003% @ 2kohm, VS= 15V
http://www.farnell.com/datasheets/37248.pdf driving 600 ohms 0.00003%
Old 21st September 2012, 12:25 AM   #16
Do you really suppose that I am unfamiliar with the datasheet performance of an LME49720? This tells me you are lacking in imagination. This is an AUDIO forum.
It doesn't matter what it says in the datasheet, you have still to achieve those figures in your implementation. You cannot simply take these numbers and add a few % for passive components and expect to predict the performance of a given layout. This tells me how little you truly understand. Electronics is highly layout dependent. Perhaps you think these numbers were achieved on a piece of veroboard? Performance like that can be thrown away with one badly routed connection.
You have either not read or not understood the material in the link I posted. This suggests to me that you are unwilling or unable to learn.
3 channel or virtual ground amps are very unlikely to achieve performance as good as amps with a true ground, even one produced by 2 batteries. So unlikely that I am confident that your measurements are meaningless.
You posted a diagram with a 741 in it that is incapable of sourcing or sinking enough current to support one 56 ohm load, never mind two. This tells me you are a novice. You ignore the fact that a 741 has barely sufficient slew rate to be used in any audio application and claim that it makes no difference and say that you used a different opamp anyway. This tells me you are overconfident, inconsiderate and arrogant.
You asked for advice. Pay attention to what I have written instead of poking out your tongue.
Old 21st September 2012, 02:19 AM   #17
few % for passive components oh you mean roughly 86 x the input distortion? that is 8600%
current draw of the lm741 is what? 20mA the entire circuit draws 13ma of current
that's 6.5ma for a single 56 ohm load you have to remember that the op amp is capable of driving 600ohms without taxing it or changing its distortion level.
Old 21st September 2012, 03:15 AM   #18
ok so my RMAA measurments are crap cause its a virtual ground lets test your theory I have a profire 2626 I/0 and it has its specs on file
THD+Noise
0.007% (-83.0dB), 1kHz, -1dBFS headphone out + instrument "DI" input
THD+N (min gain, no pad) 0.0014% (-97dB), 1kHz, -1dBFS so If i were to do a
loop back test my thd + noise should be just over .0020%
what did I measure????
Left Right
THD, % +0.0020 +0.0019
THD + Noise, % +0.0022 +0.0022
THD + Noise (A-weighted), % +0.0028 +0.0027
amazing!
Old 21st September 2012, 07:05 PM   #19
so here is the difference I was looking for, so I think I will try to improve this section on my next amp it makes it a little lean in the bass
Old 22nd September 2012, 12:11 PM   #20
xnor's Avatar
I don't think you have responded to what I wrote about output impedance.
The profire 2626 specs clearly state:
Headphone Outputs:
- Output Impedance: 75 Ohms
Have you tried putting 75 ohm resistors in series with the load? I'd suggest to EQ instead since a low output impedance means better control over the headphone drivers, but in the end it's your choice.
How to improve bass response? NVD33 Solid State 70 7th April 2014 10:10 AM
how can i improve this headphone amp bluegrass Solid State 3 29th March 2011 02:50 PM
Please help me improve my headphone amp diego6339 Tubes / Valves 35 2nd December 2010 02:24 AM
Bass amp for Headphone ideas? twenty Headphone Systems 6 19th March 2009 01:14 PM
Bass guitar headphone only amp oldhernace Headphone Systems 1 14th July 2005 04:33 AM
Copyright 1999-2017 diyAudio
