Headphone Systems Everything to do with Headphones
help with caps and resisters
Old 31st August 2012, 05:07 PM   #1
dobiejoe is offline dobiejoe  United States
Default help with caps and resisters
I am building this. http://www.ti.com/lit/ds/symlink/tpa6120a2.pdf
Can anybody recommend a good company or brand of capaciters to use. I will be using 100uf,10uf,2.2uf,0.1uf, and 2.2nf caps. I will be feeding a total of 48V into this project and cant seem to find the right caps. Also what do you think the voltage on the resisters should be.? And yes I am a noob. I need to get everything sized up so that when I order a PCB it will be correct for size and spacing.
Old 1st September 2012, 12:48 AM   #2
monty78pig is offline monty78pig  England
monty78pig's Avatar
Electrolytic should be Panasonic FC series, good performance, low cost, and easy to get hold of. Any decent 5% polyester or mica caps will do for the rest. If you know the voltage on the caps then choose a value above that voltage e.g. 48V requires a 50V cap.
Hope that helps .
http://www.objectivesounds.co.uk/ With perfect linearity, it is impossible to go off on a tangent.
help with caps and resistersHide this!Advertise here!
Resisters MikeW Pass Labs 0 15th June 2009 06:17 PM
cement resisters reddish75 Solid State 7 3rd March 2008 07:59 AM
X-over resisters... MyNameIsJake Multi-Way 6 24th September 2006 05:33 AM
5 % resisters for SOZ? Selfmade Pass Labs 4 19th February 2003 08:14 PM
resisters for SOZ Selfmade Pass Labs 2 3rd February 2003 10:27 PM
