Headphone Systems Everything to do with Headphones
Audez'e LCD-2 - help needed for a DIY cable build
Old 27th August 2012, 08:47 AM   #1
Dogpile is offline Dogpile  Canada
Default Audez'e LCD-2 - help needed for a DIY cable build
This will be my first attempt at making a headphone cable and would like to know if this is the way to go about it...
Unbalanced cable using a 1/4" TRS plug and 2 mini 4-pin XLR's for the headphone end, left and right.
Is this the correct way for wire hookup? See diagram below....
Old 27th August 2012, 09:01 AM   #2
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Four pins I think don't have a standard connection so I will follows exactly manufacturer recommends as per your posted pics.
Old 28th August 2012, 06:42 AM   #3
qusp is offline qusp  Australia
qusp's Avatar
I just use pins 1 and 3 on the mini XLR 1 for + and 3 for - so for you
left channel
phono tip = pin 1 on mini XLR
ground = pin 3 on mini XLR
right channel
phono ring = pin 1 on mini XLR
Old 28th August 2012, 07:39 AM   #4
Hmmm... so does this mean it's unnecessary to short pins 1/4 and 2/3?
Old 2nd September 2012, 04:10 AM   #5
qusp's Avatar
up to you, its done internally in the headphones afaik, never had a complaint, but if you want to be 100% sure it wont hurt to short them. some places do silly things like using 4 wires, when lcd-2 is one of the easiest headphone loads around
Audez'e LCD-2 - help needed for a DIY cable buildHide this!Advertise here!
diy rca cable with Vagus 3way teflon insulated cable umut1001 Parts 5 29th August 2012 01:00 PM
(AUS) FS:All gear needed for a DIY projector: 15" LCD, Metal halide lamp, ballast etc coooljono Swap Meet 5 23rd June 2007 05:47 AM
FS: All parts needed for making DIY lcd $275 shipped!!!! echow87 Swap Meet 3 25th June 2004 08:38 PM
electrical cable for DIY speaker cable? leadbelly Multi-Way 7 13th January 2004 10:43 AM
Copyright ©1999-2017 diyAudio
