Measuring and Correction of Frequency Response for Head-Phones - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 8th August 2012, 09:38 AM   #1
tiefbassuebertr's Avatar
Default Measuring and Correction of Frequency Response for Head-Phones
What is the right way for measuring the frequency response of different headphones?
I have various models like Sennheiser HD424 and HD414 so as several sealed and "in ear" headphones.
The usual methody like practiced by loudspeaker in the near field isn't helpful and thus not for evaluate.
Thank you for comments.
Old 8th August 2012, 10:23 AM   #2
d a o is offline d a o  Denmark
Hi
I do not think that there is a unique way to do it right on, but their are some standards which makes it possible to compare the measurements with each other. but it is expensive.
In the DIY world can one be as good as another as long as you have something to relate to and can compare with.
Artificial Ear - W00001740 - EHSY (China Trading Company) - Other Environment Protection Facilities - Environment Protection Facilities
Mountain_Rice_Oppose
http://www.aes.org/technical/documen....cfm?docID=177
http://www.diy-audio.narod.ru/litr/B...asurements.pdf
otherwise ex
B&K type 4185 Ear Simulator
B&K type 4195 Wideband Ear Simulator for Telephonometry
Greetings Hans
www.diyaudio.dk/
Old 8th August 2012, 02:17 PM   #3
You can use a tiny electret capsule plugged in your ear canal. But in this case the ear canal frequency response is also included.
Then there is the inverse method: you apply the measuring signal to one side (e.g L channel), and measure the voltage at the other side (e.g. R channel) of the headphones. The two sides should be pressed together.
Old 8th August 2012, 10:00 PM   #4
http://t.co/jfYwDG54
Not entirely on topic but related, you might find interest in this article I came across a couple days ago dealing with measurement response discrepancy of artificial head/ear.
Old 10th August 2012, 06:26 AM   #5
Using the Panasonic WM61A as a Measurement Microphone
John Conover: Using the Panasonic WM61A as a Measurement Microphone
Greetings Hans
www.diyaudio.dk/
Old 11th August 2012, 02:20 AM   #6
Soldermizer's Avatar
Here are some links on EQ-ing headphones for the individual listener.
How to equalize your headphones: A Tutorial
If you are not familiar with them, there are master DIY-ers such as this, which possibly you are trying to emulate?
http://www.davidgriesinger.com/headphones.htm
Both authors point out that each person's ear (the physical part) is unique, and thus leads to differing frequency responses among different persons. Thus, even if a pair of headphones is perfect 20 Hz - 20K Hz on the Nuemann dummy or whatever, it is very unlikely to be so on YOU! Also, there is the issue of subjective loudness. I have tried EQ-ing headphones and also regular speakers with 1/3 octave pink noise and just listening to try to get them to the same apparent (subjective) level, and the results have been very fine.
Last edited by Soldermizer; 11th August 2012 at 02:28 AM. Reason: a veritable fountain of eloquence
Old 12th August 2012, 04:39 AM   #7
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default probe mic for EQ
The necessity of headphone equalization
As part of my headphone amplifier project
, I show how to make a probe microphone and using auto room correction eq - you can flatten the response of any headphone. See Linear Audio publication. ---RNMarsh
Need help measuring Frequency Response Randallm Multi-Way 8 26th May 2011 06:05 AM
Measuring Frequency Response MCPete Multi-Way 10 10th February 2009 12:36 AM
Measuring Frequency Response furly Planars & Exotics 1 17th March 2006 06:59 AM
Measuring the frequency response of a mic? mr_push_pull Multi-Way 5 30th August 2004 12:26 PM
measuring frequency response bonsai171 Multi-Way 8 18th February 2004 07:29 PM
Copyright 1999-2017 diyAudio
