Headphone Systems Everything to do with Headphones
Quick CMOY Question
Quick CMOY Question
Old 30th July 2012, 05:50 PM   #11
monty78pig is offline monty78pig  England
monty78pig's Avatar
Quick CMOY Question
I wouldn't use the output from a power cube without a smoothing cap, op-amps have excellent power supply rejection but won't be able to reject the output of a bridge rectifier without smoothing .
For a simple single supply C-Moy amplifier I'd use a 1000uF cap for smoothing. Perhaps being fed in series with a 4R7 resistor for extra smoothing.
http://www.objectivesounds.co.uk/ With perfect linearity, it is impossible to go off on a tangent.
Old 1st August 2012, 07:50 AM   #12
SnoopKatt is offline SnoopKatt  United States
Originally Posted by Leodegarius View Post
USB runs at 3.5 to 5V and 500mA, if I am not mistaken. If you wanted it into the computer, could you use a rubber mat to insulate the tin case, or make a rubber sleeve for it?
The insulation would work I believe. Would 5 V/500 mA be enough power though?
That's a good idea with the capacitor. While I had the power jack from RadioShack, I temporarily hooked it up with some alligator clips to some different power supplies, and there was a lot of noise and hum. So I will try that capacitor and maybe the resistor and see how it is!
Thanks guys! When that power jack comes in, I will let you guys know what combination works well.
Old 1st August 2012, 08:19 AM   #13
Fredfred2004 is offline Fredfred2004
In a cmoy the voltage is split so 5V would give rail voltages of 2.5v which would be very low for most chips.
You could use a simple voltage doubler (NE555) and follow it with a 10R and 10000uF RC filter which should clean it up enough
Quick CMOY QuestionHide this!Advertise here!
quick question timwebb Car Audio 10 22nd March 2012 05:16 AM
testing voltage on CMOY - a question clothmoth Chip Amps 2 25th May 2009 03:27 PM
Cmoy power supply simple question wiredmonkey Chip Amps 2 17th July 2007 12:44 AM
question about output power of CMOY georgiano Chip Amps 4 23rd April 2007 08:44 PM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
