diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Headphone Systems (http://www.diyaudio.com/forums/headphone-systems/)
-   -   Headset goes to surgery :) (http://www.diyaudio.com/forums/headphone-systems/216362-headset-goes-surgery.html)
Jordau 17th July 2012 03:10 PM
Hi :)
I have a headset with a PTT button and microphone which I really like (they are comfortable, have good sound).
The point is that I wanted to use them on a device whose input is not compatible with the plug of the headset.
Then I began to wonder if you could do a "copy/paste" and transplant the correct plug in the headset. :p
The headset has this plug:
http://www.prc68.com/I/Images/KenwoodPgmPlgw.jpg
"Amputate" the plug and "transplanting" the correct form:
http://images02.olx.pt/ui/9/82/85/12...1287864572.jpg
(Images for illustration purposes only)
Is that possible? :D
Sorry the bad english and if the question is too basic or too crazy but I am newbie in this stuff.
Thanks in advance for the help. :)
dheming 18th July 2012 07:58 PM
Seems like it would be much easier to make an adapter cable for it instead of trying to solder a new connector on the end. Those internal wires are usually all enameled and are a pain to solder. Not to mention you will have multiple wires to combine together onto the new TRS connector.
I've never seen that type of 2 pin connector before. After a quick Google search it looks like it's for use with 2 way radios. They do make adapters to convert to a 3.5mm, but they are the opposite sex of what you need: 3.5mm Earpiece Adapter For 2-Pin Kenwood Radio TH-D7 | eBay
So it's definitely do-able. You could just build your own version of this adapter with male and female 2.5mm and 3.5mm connectors.
Jordau 19th July 2012 12:31 AM
Originally Posted by dheming (http://www.diyaudio.com/forums/headphone-systems/216362-headset-goes-surgery-post3096903.html#post3096903)
Thanks for the answer dheming. :)
So, you are talking about build something like this?
https://encrypted-tbn1.google.com/im...c30b7wNxSrq6_A
I have searched everywhere looking for an adaptor like that one but I can find any that fits. :confused:
About creating a "home adaptor" i think it will be very difficult.
How do I know how many wires I need and how do I connect them? :)
Resources saved on this page: MySQL 18.75%
