| Headphone Systems Everything to do with Headphones |
I attach below a copy of a Borbely headphone/line amp design. What I cant understand (and I am probably being stupid) is how the P Channel common source mosfet Q2 is fully biased into operation.
The class A standing current form the constant current source Q3 is 10mA. That gives 2v across the 200 ohm source resistor into Q2. That gives the source of Q2 source sitting at 24-2v=22v. Now the ECC86 valve is operated at 2.35mA per side, which gives 1.17 volts across each 499 ohm resistor in the current mirror. Add 0.6V for a base emitter junction and I see the Gate of Q2 sitting at 24-1.17-0.6=22.23 volts. So that gives a gate to source voltage of just 0.23volts, yet the 2sj79 takes around 2.5 volts to be fully switched on. So my question, to anyone kind enough to help me is why does Q2 function. Is it correctly biased and if so, please explain to me how. Many thanks John |
#2 |
You've forgotten the triode end of things, the voltage on the collector of that mirror is determined by the operating point (dc condition) the 6GM8 diff pair establishes in order to close the feedback loop and drive the output to 0Vdc.
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#4 |
there are spice models for tubes too - you can sim the whole amp, poke at the sim
#5 |
Thanks to those for their input - never thought to model the circuit. I will do that.
| A bit of expert advice required for all these gainclone components | elaar | Chip Amps | 3 | 7th February 2012 05:07 PM |
| A little bit of advice if possible...?` | mashypie | Multi-Way | 0 | 13th November 2010 10:55 PM |
| quad advice required | johniss0001 | Solid State | 0 | 28th July 2008 10:14 PM |
| A little bit of advice please | 5th element | Solid State | 9 | 1st October 2004 06:14 PM |
