Headphone Systems Everything to do with Headphones
Headphone cable wiring
Old 5th July 2012, 06:27 PM   #1
Cue Rios is offline Cue Rios  Portugal
Default Headphone cable wiring
I apologize for the newb questions and please redirect if there is anywhere more suited to ask this. I was soldering a new 1/8in jack connector for my headphones and realized that for each channel the signal wire seems to touch the ground wire (no visible coating for each) throughout the cable and yet the headphones work fine. Why isn't there any shortage? Am I missing a basic cable principle?
Thank you guys
Old 5th July 2012, 06:34 PM   #2
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
There is a clear insulating material on the wires. I've seen the same.
Frank
Old 5th July 2012, 07:40 PM   #3
Thank you Frank. Is this insulating material visible at all, as in wrapped around the wires?
Old 5th July 2012, 10:46 PM   #4
jcx is offline jcx  United States
enamels, with various resins: nylon, polyesters and urethanes are used on small wires, the coating can be clear and a fraction of a mil thick
Old 5th July 2012, 11:21 PM   #5
Ok, I see! Had no idea, thanks guys
Old 6th July 2012, 12:49 AM   #6
megaohmz is offline megaohmz  United States
If you need to get the insulation off you can use a torch and burn it off, but this oxidizes the copper so be careful. Or if is thicker magnet wire, you can use a razor to scrape it off, if you need to solder it.
Old 12th July 2012, 02:01 AM   #7
TikTok088 is offline TikTok088  United States
This is helpful. Thank guys!
Old 12th July 2012, 06:55 PM   #8
HiFi1972 is offline HiFi1972  United States
Friends often ask me to fix headphones for them, they always seem have enamel coated wires like the ones you've described. The easiest way for me to work with them has been to melt a ball of solder on the tip of the element (~40w) and run the wire through the solder slowly, this seems to melt the enamel and tin the wire at the same time. Hope that helps!
Headphone cable wiringHide this!Advertise here!
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
Re-wiring a tonearm with headphone cable. mattjk Headphone Systems 1 2nd March 2005 12:40 PM
Audio cable wiring ejmdiscos Parts 1 24th May 2004 10:10 PM
Aleph 2 Wiring/cable? macka Pass Labs 12 10th August 2002 04:12 AM
