Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 28th June 2012, 07:43 PM   #1
Default Newb Going Down CMOY Blvd Hits Big Roadblock
Hi Everyone,
I’m a newb and am putting together a CMOY headphone amp for the first time. I’m using Tangent’s instructions found here: http://tangentsoft.net/audio/cmoy-tutorial/. I just started soldering a few weeks ago and don’t even know how to properly use a multimeter – at least in terms of measuring/testing circuits or connections as recommended in some of the troubleshooting threads out there. The only experience I have with mods is successfully desoldering the opamp out of an Onkyo CD player, soldering in a socket for opamp rolling, then inserting a new opamp into the socket. Since I was very pleased with those results, I thought I’d step it up a notch and try to build the CMOY.
I got through stages zero and one as described by Tangent and all was well. I executed the test at the end of stage one and the multimeter showed that I had positive DC voltage at the positive cap and negative voltage at the negative cap. Magnitudes were practically identical and the LED turned on.
I just finished stage 2 and running the test for this stage revealed a problem. As instructed, I hooked a source up to the amp then the amp to headphones via alligator jumpers. The good news is I get no heat but the bad is that when I turn the source’s volume (my iphone) up, at around half way, the sound starts to become really distorted and unlistenable. The higher I go with the volume the worse it gets. I’m not sure if this is clipping or distortion or what. All I know is that the sound breaks up once I reach half way on the volume adjust.
Does anyone know what I might have done wrong? You’ll find pictures of both the top of the board to show component placement and the bottom to show my soldering. Also included a pick of my alligator clip placement at the test phase, just in case. Hopefully that will help with figuring out where I goofed. I really thought I was being super diligent about making sure I placed components in the right holes and generally following Tangent’s instructions so I’m not quite sure what the issue is. It doesn’t really help that I have no electronics knowledge either.
One thing that I suspect may be at least part of the problem is the fact that I deviated from Tangent’s instructions in one place. Instead of using OPA2132PA for the opamp, I used a NJM5532D opamp. It is the old opamp from the CD player that I modded (as mentioned in the first paragraph above). I figured it was just sitting around so why not use it? Do you guys think that could be causing the distortion and a quick fix would be to replace it with Tangent’s recommended OPA2132PA?
Many thanks for your help with yet another newb trying to make a CMOY amp.
B
Old 29th June 2012, 12:32 AM   #2
I would change the chip the 5532 is not a FET input opamp and it will be dragging the virtual ground off centre causing distortion, it would work better with a TLE2426 rail splitter but not with the simple resistor divider
Old 29th June 2012, 09:13 AM   #3
Input bias current shouldn't cause an input offset of more than a few 10 mV. A few hundred nanoamps would hardly be expected to throw the voltage divider off by a large amount either.
One should check the DC voltages on the noninverting and inverting input pins (R2 and R3, respectively) and the output.
Old 2nd July 2012, 09:12 PM   #4
Do you get noise with the source in pause?
I had to lower the gain from 11 to 5 but I'm using the OPA2132PA.
CMOY newb Netdewt Headphone Systems 51 1st June 2012 07:52 PM
another Charlize hits the street bbaker6212 Class D 12 10th May 2006 05:43 AM
CMOY! Help a Newb, Feel Good About Yourself Wyloch Chip Amps 21 23rd March 2005 09:26 PM
Another NOOB hits the Web SNAILDARTER Introductions 3 6th January 2005 05:52 PM
Quest for Sweet Sound Hits Snag norman Tubes / Valves 0 9th January 2002 05:54 AM
Copyright ©1999-2013 diyAudio
