High end Ortho Amp on a basic Russian Tube DHT SET DIY design - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 7th June 2012, 02:41 PM   #1
regal is offline regal  United States
Default High end Ortho Amp on a basic Russian Tube DHT SET DIY design
There has been a lot of hinting around on this forum about driving power humbger orthos like the HE-500 and HE5-LE. I'll admit the first time I heard a pair it changed the way I think about headphones, these are really revolutionary in tone, presentation, illlusion of live performance etc.
If you want a hybrid, I did several simulations of the Moskido, and for the cost to build one, the performance of the Lyr is just outstanding and really doesn't justify building a DIY hybrid
Unfortunately there is little DIY (especially tube) effort for this. If you have a balanced DAC there is the wire Bal-Bal but thats about it. A SE opamp gain stage is pushing the edge with typical +-18v rails.
What I always liked about headphones was the low power requirement, making SET have practically zero audible distortion.
But orthos change that, according to Hifi-man the HE-5LE needs 2 watts headroom, thats over 16V pk-pk swing. Now I find my normal listening is more with NwAVGuy's estimate of 1/2w (from is excellent "more power blog".)
What I a presenting is a simple fairly low cost SET that should compete with the Balancing Act, WA5, Stratus, etc. The key of course is the OPT. IMHO the low winding ratio with the right wind could knock the socks of the commercial amp. B+ simply madia, ccs cascode DN2540.
The gain is lowish for a DHT amp but at 2W into the 38 ohm load it simulates with -46db2H and -56 3H, at normal listening levels the distortion should be inaudible (below -60db).
Of course rod coleman filaments are a requirement, but the tube cost saving pays for these easily.
The tough part is finding an low distortion efficient OPT transformer.
Any thoughts ?
Old 6th December 2012, 06:46 PM   #2
Electraprint does custom work, headphone level taps and silver secondaries.
You should definitely do silver secondaries for such a low level unit if you want the maximum out of it.
I have some of his custom 845 10k OPT's and they have fabulous sound.
Bob
www.PlateauLight.com
Old 7th December 2012, 12:46 PM   #3
The level is actually very high, you have to swing almost 9Vrms to punch 2Watts into an ortho headphone.
Thats like 10Watts into an 8 ohm Speaker, the difference is the current is much lower.
I haven't built this because realy I think for orthers the best solution is an SET front end followed by a mofset buffer instead of Iron. I would love to prove myself wrong and I agree that the silver secondaries might be the "answer" but I don't want to be the gineau pig
High-end Tube amp kits (all-included) regiregi22 Tubes / Valves 40 28th April 2013 06:51 AM
Which amp design for DHT tube input? andyjevans Pass Labs 11 9th October 2011 11:08 PM
Basic Q on tube amp design mrstone Tubes / Valves 4 21st August 2003 12:22 AM
High end Tube mono amp HenrikKronborg Tubes / Valves 10 22nd April 2003 08:56 PM
Copyright 1999-2017 diyAudio
