Headphone Systems Everything to do with Headphones
shooting earmuff headphones
Old 30th April 2012, 03:55 AM   #1
neebster is offline neebster  United States
Default shooting earmuff headphones
I'm thinking about building myself a second set of headphones for a cheap audio project.
I'm looking at these parts:
Peltor Hearing Protectors with Neck Band - Ear Muffs - Hearing Protection - Hearing & Eye Protection | Creedmoor Sports
and
25CE500-RO Kobitone Speakers & Transducers
Any better ideas for $30 worth of parts, or tips on construction?
When built, I will of course post pics and results.
Old 11th May 2012, 01:46 PM   #2
Top Shelf is offline Top Shelf  Canada
Top Shelf's Avatar
This is very interesting because I have a pair of Peltor yellow 98's and I want to build them intoa pair of monitor headphones for studio use. I hope you make better progress than I have, its very hard to find the perfect drivers to use( I'm still looking). Good luck
NO REST FOR THE WOOFER! 🔊😈
Old 27th May 2012, 12:49 AM   #3
I haven't yet got around to making these, and I ran across something on parts-express:
HiWave HIAX13C02-8/RH 13mm Exciter 8 Ohms 297-214
I was thinking about mounting two of those inside the earmuffs, affixed to a couple of pieces of stiff plastic or metal, cut to fit the shape of the muffs.
I think the power rating is low enough on these that they would work, and I could even use a tiny non-headphone-specific amp of some sort since they are 8 ohm.
I've read pretty bad things about these exciters in terms of fidelity when used as speakers, but never read of them being used in this manner.
Should I just go with the 600 ohm speakers, or try making a speaker with exciter/stiff material, made to fit the headphone cavity? Would it sound bad? Speculation?
Old 27th May 2012, 07:45 AM   #4
sofaspud is offline sofaspud  United States
sofaspud's Avatar
I see headphone drivers every now and then for sale on the surplus market. Full brand and specs are often lacking, of course. A good 1" or 2" FR driver would work - that's what I used when I built a similar project some years ago. They can provide surprising satisfactory results. Good drivers pulled from a set of computer speakers will have a different sound mounted into headphones, and are efficient enough to use that "non-headphone-specific amp." To go all-out, I'd look for a small woofer & tweeter that would fit the muffs.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 28th May 2012, 03:08 AM   #5
I am not negating the benefits of "normal" speakers, and in fact will probably end up using the 600 ohm kobitones. I was querying the community on the perceived efficacy of moving coil exciters for headphone usage.
Old 28th May 2012, 03:23 AM   #6
Top Shelf's Avatar
I was actually thinking of making two ways with a 2 " -" woofer" and a small dome, maybe 3/4". I guess I could just pick up surplus units and measure them on my WT2 for compatability. one thing I'm having trouble wrapping my head around is getting such small drivers to reproduce the lowest end of the freq. spectrum. I'm used to dealing with big drivers in really big boxes . Those exciters I have never personally heard, but it seems interesting.
Old 28th May 2012, 03:29 AM   #7
Top Shelf's Avatar
Neebster , I don't see a sensitivity rating on those kobitones and with such a low power handling I would hope it should be pretty high.?!
shooting earmuff headphonesHide this!Advertise here!
Help with trouble shooting CXC999 Solid State 20 11th January 2012 01:46 PM
Troubble shooting help please..... h00hbt Tubes / Valves 20 30th January 2011 02:44 PM
Help trouble shooting Christof Tubes / Valves 11 1st September 2004 02:27 AM
need some trouble shooting help Jean Solid State 41 7th October 2002 04:53 AM
Trouble shooting help NerdMike Solid State 2 29th September 2002 12:34 AM
