TPA6120 power supply? - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 25th April 2012, 06:16 PM   #1
jeepy is offline jeepy  Switzerland
Default TPA6120 power supply?
Hello, what will I miss if I use a +/- 10 V regulated PSU instead of 12-15V as suggested sometimes, to be used with a 70 ohms/120dB headphone? Thanks!
Old 25th April 2012, 09:38 PM   #2
your spl=120db per 1mW
P=I*I*R=IU=U*U/R
your amp must give : I=0,003779~0,004A=4mA(for 120db peak)
U=0,004mA*70Ohm=0,28V(for 120db peak)
with +/-10V amp can give ~ 6,5/7V of signal.
But you need only ~0,3V(for 120db peak)
for 120db rms you need U=0,3*1,4=0,42V => you can easy use +/-10V
Old 26th April 2012, 06:47 AM   #3
P=I*I*R=IU=U*U/R
Wonderful. Thank you!
What I did with TPA6120, and what's next wakibaki Headphone Systems 2 11th January 2012 10:36 AM
Power supply positive-negative-ground from a single power supply mome Power Supplies 8 9th September 2011 06:17 PM
TPA6120 as a preamp.. Dxvideo Chip Amps 4 4th September 2008 01:13 PM
TPA6120 Question Dxvideo Chip Amps 6 4th March 2008 09:14 AM
TPA6120 Power Requirements dfdye Chip Amps 8 19th February 2007 09:30 AM
Copyright 1999-2017 diyAudio
